Panasonic heat pump won't turn off - help, we had it on a timer and then tried to turn it off, after fiddling with the buttons for more than an hour we got it turned off, but now this morning it won't turn back on. It's like the remote is not telling the pump to turn on and off. The batteries are new. Any ideas?
    Sergeant:
    Champion:
  • 282 Answers
Try cutting the power off and wait about 30 seconds and turn the power back on. What I mean about turning the power of is to either ulplug the unit or flip the circuit breaker off.
These units have a pc board with memory and by turning off the power you make it reset itself.
I hope this works for you.
Marty
Posted on May 11, 2014
Sea Breeze
  • 4654 Answers
SOURCE: Goodman split not responding to remote
First turn the main power off to the unit at the breaker, wait about five min. and switch the breaker back on, then see if this solves the problem. In the instalation manual that came with the unit on the last page you will see a code of the red blinking light, this will tell you the most likely problem if not solved by switching the breaker on again.............Hope this helps
Posted on Oct 21, 2007
bobotfel
  • 236 Answers
SOURCE: green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Posted on Mar 09, 2008
daddyo742001
  • 70 Answers
SOURCE: My LG LAN125 mini split heat pump occasionally
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Posted on Jun 28, 2009
  • 81 Answers
SOURCE: Hi, I have a KSR27g split system air conditioner.
Judging by the model number, it is a Kelvinator unit. You can check if the remote works by using your phone or digital camera. When the camera is on, press a button on the remote whilst aiming the remote transmitter at the lens of your camera. If you can see a burst of light, the control works and the receiver on the indoor unit is the problem. If not, the remote is the problem.
Hope this helps
Mat
Posted on Jul 17, 2009
SOURCE: dometic control comfort control will not turn heat on or off
I had the same problem. I fixed it by turning off the battery switch to disconnect the battery from the power panel. I then had to turn off the main 110 breakers to shut down the converter. Once all the power was turned off the LED light went off. When I turned the power back on the remote was working fine. Hope this works for you.
Posted on Jan 22, 2010
I accidentally overheated my Panasonic Plasma TV TH-42PZ700U. It won't turn on, and the power button is just blinking. What can I do?
All you can do is: Take the plug out of the wall (power) - wait 2hrs, plug in and try again. If it will not work after being cooled and the capacitors drained (which this will do) then it needs repair.
Mar 20, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
After putting a new lamp in the projector in my PT-AE1000U, it turns off on it's own after 5 to 8 minutes of use. I was told it could be a BIOS setting that counts the hours of use that needs to be zero's...
Generally speaking a lamp timer is just a warning indication and won't shut the unit down. There should be indications of why the unit is shutting down. For example, is the power LED blinking or any other light blinking? My primary suspicion would be either an air flow problem or heat. Check to be sure that the fans are running properly.
Please update this with any additional detals.
Thanks,
Dan
Apr 25, 2011 | Panasonic PT-AE1000U LCD Projector
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
I can't reset the hour counter and I have no sound
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
As for sound, more info is required.
I hope that helps.
Dec 26, 2009 | Panasonic PT-52LCX66 Projection Television
The lamp hour meter needs to be reset for Panasonic PT-52LCX66 Television. How do i reset it?
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-52LCX66 Projection Television
Lamp Timer Reset procedure Panasonic Projector PT-L759E
Greetings!
It's been a while since I did one of these, but if I remember correctly:
- Turn on the set
- Push volume down on remote and at the same time....
- Push Split on the remote and hold both for 5 seconds
This should do it. The display should reset to "0".
Rob
Jan 05, 2009 | Office Equipment & Supplies
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
