Question about Fisher and Paykel WA37T26G Top Load Washer
Why is the washer Full of water but won't power on?
  • Fisher and P... Expert
  • 555 Answers
It sounds like the pump has went bad & also taken out the main board.
Common fault is pump.
why is the washer Full of water but won't power on - 2b0b168f-92e1-4e79-ac42-7cdf49d0c6a5.jpg
Posted on May 11, 2014
  • Greg Stephen
    Greg Stephen May 11, 2014
    Have a technician replace the fuse in main board.
  • Greg Stephen
    Disconnect from power & turn water Bail out as much water as you can, Before you remove the pump.
    New Friend:
Hello
If the washer fills with water then stops, and will not agitate or spin, the lid switch is bad and needs to be replaced.
Posted on May 10, 2014
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't empty and spin
You either have a blocked water pump or more likely a blocked diverter valve. Easy to fix if you are handy. Tip machine back on a 45 degree angle and let rest against the wall. It is a matter of disconnecting a coupe of clamps and twisting the pump counter clockwise.
Dec 25, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Door won't open on my GE gfwh2400lww
Gather towels, shop vac, mop....Open small door at the bottom of the washer on the outside. Remove the small door and cup that's attached to it. Be prepared for a washer full of water!!!!!! Reach in, turn the nob to the left so tht water and debris can escape. You need to do this every 5 loads to keep debris from building up and causing the door to lock.
Aug 31, 2012 | GE GFWH2400LWW Washer
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Kenmore 43142 Front Load Washer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Fisher and Paykel WA37T26G Top Load Washer Logo
132 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
