Question about Maytag Bravos 3.8 Cu. Ft. Washer
What is causing the LF code on my Kenmore Oasis?
  • Maytag Master
  • 2,671 Answers
Lf is an error for long fill,you could have sediment in the water valve and you might have to change the valve but it's taking to long to fill,shut off the water to washer,remove the water lines and mark them so you know what line is cold and hot so they go back on correctly,look into the back of the water valve and see if the screens are blocked with junk from the water,also after you have the hoses off,stick them into a sink or into the washer and turn the water back on and make sure the house water valve is working ok,this is where you want to start
Posted on May 17, 2014
What is the LF code on my kenmore elite oasis
The LF code stands for long fill.. I would suspect a water inlet solenoid valve as the most likely suspect. It may be the hot or the cold valve. If the valve does not completely open the time to fill your machine takes too long. You can't replace just the one valve because the part contains all of the water inlet valves. That of course jacks up the cost but what can you do.
Jun 29, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore Washing Machines
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
What do I need to do to fix the Lf code problem on my oasis washer?
Following is the LF troubleshooting response from the Whirlpool Cabrio
Service Manual. The Cabrio is the same as the Kenmore Oasis.
“LF” (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Are both water faucets turned on?
Is the drain hose sticking too far into the
standpipe (siphoning)?
Is the pressure transducer hose kinked or
dislodged?
Press PAUSE/CANCEL to clear display.
It takes a while to load but following is the manual in PDF format.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Dec 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The dreaded LF code
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
Jun 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore oasis long fill
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27092
LF means long fill or that is what the repair tech told me when I first got my set and was having major issues with it. What he said was causing it during initial fill up the drain hose if inserted into the drain to far will create a siphon. It is a simple fix just barely put your drain tube into the wall and you should be set.
Jun 01, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
LF error code
I had the same problem this weekend. Sears said they would have to send someone to fix it. Now I have to wait til Wednesday. It better be fixed then! It's only a month old machine, and I'm livid.
Jan 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Bravos 3.8 Cu. Ft. Washer Logo
181 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
