Question about Kirby Generation 3 Bagged Upright Vacuum
Splicing kirby electric cord
My Kirby G6 electric cord wires broke where it hooks onto the handle (a common issue). I can splice the wires, but does it matter which way the wires are reconnected? I don't want to splice to incorrect wires and damage the motor.
  • Kirby Expert
  • 324 Answers
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Posted on Oct 15, 2014
SOURCE: Vibrating and noisy Kirby
Power off the vacuum.
Unplug the power cord from the wall.
Remove the head or hose attachment.
Look at the fan and make sure all the fins on the fan are there.
If part of one or more is missing it will cause the fan to wobble and shake.
Posted on Oct 19, 2007
SOURCE: owners manual for kirby g6
The Kirby G6 Vacuum Manual is available for free on this site: http://ubermanuals.com/product/kirby-g6-8499 .
Posted on Jan 26, 2009
b0sslady2001
  • 357 Answers
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
Posted on Jun 28, 2009
  • 231 Answers
SOURCE: Our Kirby g6 vacuum cleaner will not turn on and
you probably have a bad switch. let me know if you want me to walk you through replacing it
Posted on Jan 03, 2010
VacuumRepair
  • 438 Answers
SOURCE: i need to replace power supply. where the cord
Greetings from GoVacuum.com,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Chris Jones
Posted on Mar 21, 2010
Wont **** properly. is just moving dirt around. i have a G6 i unclogged it changed the bag. dont know what else to do.
With a Kirby that's around 10 years old, there's a good possibilty the fan is worn or broken. You can purchase one online (http://www.elikirbyclub.com/category_93/Kirby-GSix-Fan.htm for $17.55 plus shipping and handling) or at a Kirby store.
Instructions for replacing the impeller can be found at the following site.
http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html
Jan 03, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Replace power cord on Kirby G6
The Kirby vacuum cord can be found at http://www.totalvac.com/K-192099ES.html
Jun 16, 2010 | Kirby G6 Bagged Upright Vacuum
My Kirby G5 has stopped working, last few times it was used it kept cutting out everytime the handle was moved??????????
This definitely sounds like your cord is bad. The reason that I specifically think that it's your cord is because the cord is actually connected into the handle, and is attached to the handle in the back. This would make sense why the machine was cutting off every time the handle was moved.
Also the cords are notorious on Kirby's for going bad, and are usually the only thing that goes bad on a constant basis.
Here's how you can check to see if your cord is bad or not:
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums2_bing.gif I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
Chris Jones
GoVacuum.com
Apr 14, 2010 | Kirby G5 Bagged Upright Vacuum
I need to replace power supply. where the cord
Chris Jones
Mar 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Just stops and starts while vacuuming - won't keep running
Probably a loose wire or other electrical connection .Possibly a broken wire in the cord,if it flexes excessively in one spot or feels too warm the cord could be the trouble.
Jun 04, 2009 | Kirby G6 Bagged Upright Vacuum
Ran over cord and the vacuum shut down, won't
sounds like it might have broken a wire in the cord and may have to replace the cord unless you can find the broken wire and splice it back together
Apr 23, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
Changing a belt on kirby G6
I have written an online guide to help with this issue. Click on the link to view the guide.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Oct 15, 2007 | Kirby G6 Bagged Upright Vacuum
G6 cutting out
Hi There, If it keeps cutting out when you move the handle it's usually the cable that has gone. Turn the machine on and waggle the cable if it cuts in and out then you can confirm it's the cable. Many Thanks Chris www.elidistribution.co.uk
Sep 14, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
94 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
