Question about Craftsman Garden
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
Pull start cord won,t retract spring seems to be working how do i get cord back in
  • 3 Answers
The one way clutch could be broken or jammed. Take off the starter for a closer look.
Posted on May 10, 2014
mowerman1857
  • 389 Answers
SOURCE: I have the option to purchase a craftsman lawn
If it has a Briggs&Stratton engine, find the Model - Type - Code numbers on the engine. Using the Code numbers the first six numbers will tell you the date the engine was made si it would be fairly safe to assume that the tractor is the same year model.
Code number is read like this - 090821 this wouod indicate that it was made in 2009 08 - August -21 - 21st day of the month
Posted on Sep 17, 2009
frederiquema
  • 76 Answers
SOURCE: snowblower pull cord
Not the cords problem its the pull back mechanisim
Posted on Oct 26, 2009
  • 2841 Answers
SOURCE: How do I switch the
Your Barracuda has a inlet restrictor installed that must be removed when you use it as a vacuum. With the unit unplugged and off, open the inlet cover by inserting the tip of a screwdriver into the latch area on the vacuum inlet cover. Gently tilt handle of the screwdriver toward the front of the unit while pulling on the vacuum inlet cover with the other hand. Turn the inlet restrictor located inside counterclockwise to remove it from the unit. Do not close the inlet door. You will next attach the vacuum tubes. There are 2 tubes, a lower and upper. The upper tube is cut straight on both ends and attaches to the blower unit. The lower tube attaches to the upper tube and one end is cut at an angle. Locate the arrows on the upper tube and the arrows on the vacuum inlet areas. Line the arrows up and insert the tube into the opening on the unit and then twist clockwise until it seats. Install the collection bag over the blower outlet and secure with the velcro strap. You are now ready to use the unit. Here is the owner's manual with instructions and photos. http://72.3.225.179/manuals/545117523e.pdf
Posted on Oct 02, 2010
woobie dog
  • 1273 Answers
SOURCE: when I pull the pull
Hello, W/D here.
Most of the recoil starters have ball bearings in them, and the centrifugal force that you apply pushes the balls out where they engage pawls and allow the flywheel to be rotated. Since your's is on a snowblower, you may just be stuck, or moisture could be in the mechanism, freezing the ball bearings in place.
The quickest thing to try: Rap the recoil mechanism in the middle of the top, with a rubber hammer. You want to jolt it, without denting it. Try to pull the cord and see if it engages. You can repeat this several times, but try not to dent it.
If the machine is outside, and you believe that the mechanism may have frozen, you can apply heat to it with a hair dryer, and then rap and try.
Try these out and repost if the problem persists.
Best regards, W/D
Posted on Feb 03, 2011
vincob
  • 718 Answers
SOURCE: need assistance on how to
Go to smalleng.com or check out U tube..
Posted on Apr 19, 2011
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Need to change pull cord on craftsman weed eater mdl#316.790101. The manual does not describe this maintenance, so I am looking for assistance before I randomly start pulling screws out.
It should be pretty straight forward just pay attention on how you take it apart and beware of the spring that helps the line retract.If the spring coil comes out it could be fairly difficult to put back in but it should be able to be done.I have done this on lawn mowers but the basic principle should be the same.Hope this helps and would it be possible to get a copy of your owners manual?I cannot find one anywhere including Sears.
Thanks
Jun 05, 2010 | Craftsman Garden
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
May 04, 2010 | Craftsman 25cc Gas Line Trimmer
Starter cord pulled out of the housing, it
if it's new take it back should have a one year warrenty on it if yo can't get it done for free get back to me so I can help you you may have a damaged windind head.
Apr 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Nov 16, 2009 | Craftsman Garden
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Repalce the pull cord a Craftsman Weed eater 32CC
I have a craftman weed eater model M358.796600 and the pull cord will not retract any more...how do you fix it?
Drew
Jul 02, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
