Question about Garden
Directions on how to change oil on a Workhorse 163CC pressure washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Gearbox or motor?
Posted on May 15, 2014
Kingcraft 163cc 2400psi. Where can I get parts?
what are you looking for. please email @dennys23601@hotmail.com for more info
Jul 20, 2015 | Garden
How to change oil on Workhorse 163 CC pressure washer
There will either be a drain plug in the side or on bottom of engine.
you can also tip the engine and pour it out from the fill port.
May 10, 2014 | Northstar Garden
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Home lite ovh pressure washer 163cc. Do you supply parts for this brand
check the brand of engine... If it DOES NOT say Briggs & Stratton, Kohler, Kawasaki then you are going to have a hard time finding parts... Supply us with the brand name/model and serial numbers and your location. only then can we send you off into the right direction
Nov 22, 2013 | Garden
Just filled oil reserve with HD30 on a Workhorse model # WF 80710 and all of a sudden large amounts of thick white smoke out of exhaust? What the heck is happening.
White smoke is ok, just a worning that you probably put 2much oil or wrong type of oil 4your model, or your engine still cold, warm it up than check... If you have a black smoke blowing, than you defenetly 100% have a problem and most time assosiated with your head & head/gasket
Aug 16, 2013 | Garden
How much oil in ryobi rpw 2400 power washer engine?
they take from a half a quart to a full quart
Aug 10, 2012 | Garden
How do you drainoil so you can change the oil in Honda Black Max 2600 pressure washer?
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
May 04, 2011 | Honda Black Max 2600 PSI Pressure Washer
I can't find my manual and no longer remember what the fuel mixture is for my workforce 163cc power washer. Can you help me? Thanks much.
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
Jul 17, 2010 | Northstar Pressure Washer 3000 PSI
What oil do i use in the pump? The oil is milky and needs changing.
Well you can use direct recommended from Ace Hardware see link.
http://www.acehardware.com/product/index.jsp?productId=1340266
They recommend 250 hours, but i'd change more often, like you said when it's milky. If it begins to get water in the oil sooner, that indicates your piston to crankcase seal is beginning to leak.
Jun 21, 2010 | Mi T M WP-3000-4MHB Pressure Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
