Question about Northstar Garden
How to change oil on Workhorse 163 CC pressure washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
There will either be a drain plug in the side or on bottom of engine.
you can also tip the engine and pour it out from the fill port.
Posted on Jun 11, 2014
Home lite pressure washer 163 cc do you have parts for this
If you are looking for parts for this machine, you'll need to know the model number; if it is for the engine, the name (Honda, Briggs & Stratton, etc.) and the model number to it. If you still have the owner's manual, there is usually in the appendix, a schematic along with a parts list page.
You can easily go online and enter the "Home lite" brand name of the pressure washer, the model number plus the words owner's manual.
Same thing for the engine.
There are many online manual sources.
Nov 22, 2013 | Garden
Just filled oil reserve with HD30 on a Workhorse model # WF 80710 and all of a sudden large amounts of thick white smoke out of exhaust? What the heck is happening.
White smoke is ok, just a worning that you probably put 2much oil or wrong type of oil 4your model, or your engine still cold, warm it up than check... If you have a black smoke blowing, than you defenetly 100% have a problem and most time assosiated with your head & head/gasket
Aug 16, 2013 | Garden
Grease is getting on my clothes while washing.
DO NOT USE IT ANY MORE ...thats your bearings grease ...there no good you need new tub assy ... £££££££££££££££££££ sorry to say ... bsc appliances 07779933829 uk
Feb 26, 2011 | LG WM2301HW Front Load Washer
Where do you add the oil on a DeWalt 3100psi pressure washer?
Hi and welcome to FixYa, I am Kelly
From reading everything I can find, i.e User's manual & parts manual the only thing you add oil too is the engine. The pressure pump does not have a liquid sump.
You can look at parts here detail D:
http://www.ereplacementparts.com/dewalt-dpd3100-pressure-washer-parts-c-1009_7440_7445.html
So too add oil to the engine you would remove the dip stick from the crank case located on the opposite of the side of the engine as the oil sensor.
I recommend you use 30 WT SAE oil for 3 oil changes then on the 4th oil change use an HD 30 WT oil. The oil drain plug is located in the center of the side of the engine crank case base. On the 5th Oil change switch back to SAE 30 WT oil. Oil brands are not really important. They all have to meet SAE the same standards to carry the label of SAE. (Yes you can use a generic 30 WT SAE oil )
Thanks for choosing FixYa,
Kelly
Dec 06, 2010 | Dewalt DPD3100 Gas Pressure Washer
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
How to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
May 21, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
71 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
