Question about Vivitar ViviCam 5385 Digital Camera
Vivicam S529 lens error
The camera keeps saying lens error and then shuts off. How can I fix this
SOURCE: vivitar vivicam 5386
I have had that problem too. All I had to do is change the battery. But don't mix match batteries good luck.
Posted on Mar 19, 2007
SOURCE: vivitar vivicam 5385 digital camera
wont power on even with new batteries please email m e with suggestions www.aol.com
Posted on Oct 17, 2008
spentza_will
  • 48 Answers
SOURCE: vivitar vivicam 7388s lens won't go back into
Hi Dear,
This issue is not with the battery. This is due to the misalignment of the camera lens. This is a delicate hardware problem. Hence,i would suggest you to take it to some professional or your authorized service center and get it repaired there only. Trying to repair it on your own might make the situation worse and would cost a lot money.
If you need more information on this. Please do write to use.
Have a nice day.
Posted on Nov 09, 2009
  • 11967 Answers
SOURCE: i have a vivicam 3755 (no 3A30009825) MY CAMERA
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 10, 2010
rajdeepdutta
  • 2517 Answers
SOURCE: after turning it on, it says lens error and shuts
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Posted on Apr 11, 2010
I lost my CD for my ViviCam S529. How do i download the drivers and software now?
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or , despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 26, 2014 | Vivitar Vivicam S529 Digital Camera...
Lens will not close
Replace it under warranty. It is Broken and You can not fixt it.
Jan 15, 2014 | Vivitar ViviCam S529 Digital Camera Grape
How do i change the storage function of a vivicam s529
What happens when you try to format the card in the camera?
Feb 19, 2013 | Vivitar ViviCam S529 Digital Camera Grape
Vivicam s529
You may download a copy of the manual here.
Nov 05, 2012 | Vivitar ViviCam 35 Digital Camera
After turning it on, it says lens error and shuts
Apr 11, 2010 | Vivitar ViviCam X327 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2008 | Vivitar ViviCam 5385 Digital Camera
Lens error
you can't fix it by yourse. You need it to send for repairs.
Jul 27, 2008 | Kodak Easyshare M753 Digital Camera
Vivitar 5386
i suggest that you take your camera to a profesional camera shop, like Jessops, and see what they say. if they cannot fix it then just buy a new camera.
Dec 24, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivicam 3750 error
You might have error on lens mechanism. Maybe a gear or two is broken in the lens system and when turned on gear is not moving to extend the lens to start position. See if you can jiggle the lens slightly while turning the main switch on. If the gear is lightly damaged, it might catch to right position otherwise need new lens assy for the repair.
Mar 12, 2007 | Vivitar ViviCam 3750 Digital Camera
Lens error
Jan 13, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
61 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
