My washing machine is tearing or ripping my close when it washes why?
  • moretank Jun 23, 2009
    My washer is tearing our clothing I don't do big loads and we checked with our hands for sharp objects and don't feel any
    Scholar:
  • 122 Answers
I will assume that this is a top loader?
The spindle in the middle most likely has excess play. Grab the center spindle and see if it moves up and down. If so, it will need repair or replacement. If you aren't up to tackling this yourself, you will have to find a local repair shop. You can attempt repair yourself if you have basic tools and an afternoon free, and are at least slightly mechanically inclined. Remove the belt and the drum to access the spindle mount. Check the mounting bolts and make sure they are tight. If the bolts are tight and there is still excessive play, the drum will have to be replaced.
Posted on Jun 23, 2009
  • Washing Mach... Master
  • 13,433 Answers
If your washer has developed a bad habit of snagging and/or tearing your clothes; before tossing your washer, try these few tips:
1) Check, by hand, the smoothness of your washer. Look for any broken fins or roughness on the basket surface. Replace, if necessary.
2) Reduce the size of your loads. Heavy, cramped loads can cause a lot of friction which leads to tears.
3) Reduce the amount of bleach used. Bleach can eat holes in clothing.
4) Verify water level is not too low, especially during rinse cycle, where snags are more apt to occur.
5) Consider placing delicates in a garment wash bag
6) Front load washers have no center agitator, so they are less likely to tear clothes.
could be that theres something inside the washer that isn't supposed to get in there, maybe metal got in with the clothes, do step 1 with great detail and care to find out if theres something sticking out, careful not to cut your hand.
Top load washing machine damaging cloths
In what way are they getting damaged, and is the machine under warranty?
Apr 18, 2017 | Amana Washing Machines
Leaking from door
Hi Bungle
Door leaks usually mean that there is a tear in the door seal which is allowing water through. OR it could mean that you keep the door closed between washes which doesn't allow the flexible seal to relax.
If it's the latter situation, leaving the door ajar between washes MAY help.
If it's ripped/damaged you'll have to have it replaced. Not a job for the handyman as sometimes 'special tools' are needed.
Usually the front panel has to be removed to access the rear clamp and the counterweights removed..
Good luck
Nomess
Jan 30, 2015 | Washing Machines
Whirlpool washer rips my clothes and wash rags
Worst case. The usual cause of this is that the drum bearings have callapsed and there is now a lot of "play" between the wash drum and the outer drum catching the washing inbetween them as the drum turns. This would be accompanied by a a very loud noise.
Best case. clothes gaurd has broken and tearing at the washing at the drum turns.
Oct 03, 2014 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
TEARS WASH
What is the model number of your unit?
Nov 21, 2012 | Amana Washing Machines
How to change the bellow ion the front loading washing machine, the bellow is the seal between the door and drum
The bellow does wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Also DO NOT overload the washer. This can contribute to premature wear of the door bellow and cause rips and tears.
Apr 15, 2010 | Kenmore 43142 Front Load Washer
Torn rubber gasket
The front door seal is referred to as the "bellow". They do wear out with age and can also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Apr 08, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Front load washer, tear in the boot that the door close
The front door seal is referred to as the "bellow". They do wear out with age and also become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer sealing correctly, the following link explains how to replace one:
repairclinic.com
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
