Question about ACE Water Timer, Electronic - No. 7198476
Do I place this at the faucet or after the pressure regulator on drip system?
  • 5,471 Answers
Generally you put these timers at the hose bib (faucet). In my home, they'd be used for sprinklers or drip irrigation systems that have a limited controls on them. If I put them past the flow restrictor on the soaker hose, the unit would be on the ground and in the water.
I hope this helps.
Posted on May 10, 2014
  • Desert Converters Aug 06, 2014
    I do not recomend the answer provided as it will shoten the life of you unit these units are Not water proof/vs water resistance
Water dispenser drips after use but doesn't shut off completely and drips constantly.
Most likely the water inlet regulator (water valve) is faulty (like a leaky faucet) need to replace the water valve.
Jan 30, 2014 | Samsung RF26XAERS
How do i stop a slow drip in a tub faucet?
A drip is caused by seepage from the water supply. Remember the water supply enters your home under pressure, so there must be a watertight seal holding back the incoming water when the faucet handle is in the OFF position. That seal is usually created by a washer pressed tightly against the faucet seat. Obviously, when the washer or the seat is not functioning properly, a little water can seep through and drip out of the faucet spout. To stop the drip, all you usually have to do is replace the washer or repair the seat.
Jun 01, 2012 | Home
My husband just replaced a bathroom faucet yesterday and it is dripping. did we do something wrong? and what should we do? Thanks It is a moen faucet.
If this is a brand new faucet and hubby hasn't taken it apart i would take it back where I bought it. It should not be dripping at all. Just installing it I can't see where he could have done anything that would make it drip from the faucet unless the drip is from a fitting he didn't get tight enough somewhere. If the drip is at the spout take it back and get a new one they are gauranteed and the place you bought it should replace it for you no problem.
Mar 13, 2011 | Plumbing
I need to know how to adjust pressure at water pressure regulator
Loosen the stem retaining nut with an adjustable wench. Open a faucet or two and let the water run while adjusting the pressure regulator. Turn the valve's stem counterclockwise to increase the pressure and clockwise to decease. Tighten the retaining nut when you are satisfied with the water pressure.
Aug 28, 2010 | Watts Plumbing
2000 Malibu Starts then looses fuel pressure I have replaced the fuel pump and the fuel pump relay still same problem
Keep in mind that you have several components there:
- Fuel Pump Sender Assembly,
- Fuel Pressure Regulator,
- Fuel Rail Assembly, and
- Fuel Injectors.
1.- Fuel Pump (Sender Assembly) - TESTING
Refer to the accompanying charts for fuel pump diagnosis and testing.
The fuel injection system remains under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
Fig. 3.1L engine OBD system check to be done before fuel pump relay circuit diagnosis
Fig. 3.1L engine fuel pump relay circuit diagnosis (1 of 2)
Fig. 3.1L engine fuel pump relay circuit diagnosis (2 of 2)
Fig. View of the fuel pressure test port (Schrader valve)-3.1L engine
A - 3.1L engine fuel system pressure test (1 of 4)
B - 3.1L engine fuel system pressure test (2 of 4)
C - 3.1L engine fuel system pressure test (3 of 4)
D - 3.1L engine fuel system pressure test (4 of 4)
Fig. The fuel pump/fuel sender module assembly is mounted in the fuel tank
2.-
Fuel Pressure Regulator - REMOVAL & INSTALLATION
(the fuel pressure regulator, which is located on the fuel rail assembly)
NOTE:
Before removing the fuel regulator assembly, place a clean shop towel under the regulator to catch any fuel drips
  1. Properly relieve the fuel system pressure.
  2. If not done already, disconnect the negative battery cable.
  3. On the 3.1L engine, remove the intake manifold plenum, as outlined in .
  4. On the 2.4L engine, remove the fuel rail. Refer to procedure earlier in this section.
  5. Detach the vacuum line from the regulator.
  6. Place a shop towel under the regulator to catch any fuel that may drip out. Unfasten the fuel pressure regulator retaining screw, then remove the regulator by twisting and pulling it from the fuel rail.
  7. Remove and discard the O-ring seal. Inspect the filter screen for contamination and replace if necessary.
To install:
  1. Prior to assembling the pressure regulator to the fuel rail, lubricate the new rail-to-regulator O-ring seal with clean engine oil.
  2. Place the O-ring on the pressure regulator and install the pressure regulator to the fuel rail.
  3. Install the retainer or coat the regulator mounting screws with an approved thread locking compound and secure the pressure regulator in place. Tighten the mounting screw to 76 inch lbs. (8.5 Nm).
  4. If removed, install the fuel rail assembly to the engine.
WARNING The fuel return pipe must be connected before tightening the regulator retaining screw to prevent the regulator from rotating. Rotation of the regulator could damage the retainer and spacer bracket and lead to a fuel leak at the regulator inlet.
  1. Connect the fuel feed line and return line to the fuel rail assembly, use a backup wrench on the fittings to prevent turning.
  2. Attach the vacuum line to the regulator.
  3. On the 3.1L engine, install the intake manifold plenum.
  4. Connect the negative battery cable. Turn the ignition to the ON position for two seconds, then turn it to the OFF position for ten seconds. Turn again to the ON position and check for fuel leaks.
continue...
May 24, 2010 | Chevrolet Malibu Cars & Trucks
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Do I turn the faucet on fully?
Yes, when using an inline water timer, it does not control the pressure of the water, only the "on/off" of the pressure. So make sure to keep the faucet at the pressure you want the drip system set at as if you weren't even using a timer.
Jul 19, 2009 | Garden
Water system in my Coleman pop up not working
Make sure you have a water regulator connected to the water source before connecting it to your RV or the pressure could blow out your plumbing. The force of the water coming from the faucet can be too much for any RV and a regulator can be purchased from RV dealers, camping world, and even some Wal Marts carry them.
Jun 22, 2009 | Coleman Campers Grill
DRIPPING OLD BEVERAGE AIR FAUCET
New faucets are easily had from many places like beveragefactory.com, northerbrewer.com, austinhomebrew.com, micromatic.com, etc. You should also be able to find replacement washers/o-rings for your current faucet, but it may require an email or phone call to one of the sales reps to locate one. If you decide on a new faucet consider a Ventmatic (Shirron) forward sealing faucet. Much better design that drips less and doesn't stick after sitting a few days. The only issue I've seen is that the machined grooves in back of the faucet may not mate up with your current shank requiring a machined (as opposed to cast) shank to match.
Nov 01, 2007 | Beverage-Air MT27 Beverage Cooler...
ACE Water Timer, Electronic - No. 7198476 Logo
171 people viewed this question
Top ACE Garden Experts
Craig Butler
Craig Butler
Are you an ACE Garden Expert? Answer questions, earn points and help others
