Question about Revere McMurdo Fastfind 406 PLB Battery
Need battery replacement for 406 McMurdo
See aove
Air con problems on my peueot 406
if there is no air movement check the fuses as the one for the fan might need replacement, if there is air movement but it is not cold then you may have lost gas from your aircom system which will need to be replaced by a specialist.
i hope this was useful
Feb 25, 2013 | 1999 Peugeot 406
Karbonn k 406 battery connecter jumpers
Jan 05, 2013 | Cell Phones
Peugeot 406 key fob not operating central locking
406 FOB / PLIP PROGRAMMING :
The 406 deadlocking remote control has specific button controls, and if the vehicle has two controls, one is set as primary and the other as secondary.
When replacing the Plip, a Primary or Secondary Plip are different part numbers and must be ordered as required. The white label inside the Plip is labelled PRIM or SEC.
1. Turn the Ignition switch ON.
2. Press the large Plip key button (Primary Plip)
3. Within 10 seconds press the large Plip key button (Secondary Plip)
4. If there is one remote, press the Primary plip button twice.
5. Turn ignition OFF.
6. Test Plip's for correct operation.
NOTE : On some 406 models, Plips cannot be re-synchronised unless the battery has been disconnected for 1 minute
Oct 27, 2012 | Cars & Trucks
Peugeot 406 hdi electronic immobiliser warning
The ignition key may be defective or in need of a battery to generate the code needed to disarm the immobilizer. Hope this helps!
Mar 05, 2010 | 2005 Peugeot 405
Battery replacement
Best bet is buy it online either from the manufacturer or a 3rd party.
May 16, 2009 | GPS
Error Code 406 EGR Positions Sensor
yes it is..you need to replace egr valve assembly..make sure you disconnect battery while replacing..some times fault will return even after replacing valve..
Mar 15, 2009 | 2005 Dodge Caravan
Revere McMurdo Fastfind 406 PLB  Battery Logo
283 people viewed this question
Top Revere GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Revere GPS Expert? Answer questions, earn points and help others
