My Toshiba CT 8002 won't turn off standby. When I press the power button on the remote, it clicks as though it will turn on, and then clicks straight back to standby. Any suggestions? Thanks in advance! :)
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Posted on May 11, 2014
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
SOURCE: lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Posted on May 18, 2008
SOURCE: Power issue with Olevia LT23
this is bull do...The same thing happens with my TV I Have the Olevia 23" and the power will not turn on.
$700 shot, who cares about the rebate when it works on a short while...
Posted on Nov 24, 2008
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
Posted on May 18, 2009
jerryg50
  • 1667 Answers
SOURCE: the red standby light flashes and when the power
One of the boards (module) has a short on it, and or the power supply itself is failing.
The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
Jerry G.
Posted on Dec 16, 2009
Can I turn on a Toshiba 32L4200U without the remote?
Yes! As you face the TV screen on the left hand side panel, the top button is the power button.......it will either turn on or to standby......if it goes to standby press one of the next 2 buttons which are the channel up and down buttons!
Oct 23, 2014 | Toshiba 32L4200U - 32in Class 31.5in...
I have a Toshiba CT 8002 tv that won't turn off standby. Each time you press the remote it clicks as though it is turning off but doesn't, it just clicks back to being on standby. Any suggestions?...
May 10, 2014 | Televison & Video
I have a toshiba ct 90159 - I need the code for a coby dvr model dvd 627
u should be able to
turn the dvr on
press and hold the setup until the light stays on (remote)
hit the dvr botton on the remote the light should blind once
hold the remote towards the dvr keep hitting the on and off button on the remote until the dvr turns off can take up to 300 times once the dvr turns off press the select button and that should fixya up
Mar 31, 2012 | Toshiba CT-90159 Remote Control
Operating Manual for aToshiba CT-9371 remote or TV #CX2769J
press menu or red button ( NOT STANDBY ) find pic format( aspect ) and change screen size to match tv
Nov 07, 2009 | Toshiba Televison & Video
I cant figure out which button is for the code search on this remote
It should be channel up button. Just keep pressing it, allowing 3 seconds in between presses. Once your television turns off, you have found the code. Then press enter, and try turning your television back on. (Note: not all televisions will power down. Some may only change the channel)
Nov 04, 2009 | Toshiba CT-877 Remote Control
Programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Toshiba CT-90157 Remote Control
Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Jan 10, 2008 | Jensen SC-340A Remote Control
Help I am locked out ! Sony DAV S 550
Hold down the eject button for about 10 seconds
Sep 02, 2007 | Fisher DVD-SL30 DVD Player
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
