Question about Philips 60PW9363 60" Rear Projection Television
Dull picture in all situations
Recently received a 60PW9363 for free which is great, but the picture just seems dull. Tried adjusting every setting but I just could not get a decently sharp, bright picture out of it. Everything I watch on it is much darker than it should be. I have no idea what's going on here and would greatly appreciate some information or advice.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 65 Answers
In the setting section click on picture and go to color warmth there you can change from cool to mediam and hot
Posted on Jun 23, 2009
Color looks white washed!!!
there are in the older rear projection sets lens for those that do not use a lamp for a light source.
In the older sets there are three large black lens that can be seen and reached with the rear cover off---if there clean them as they are the light source in those sets and if dusty picture will look dull and darker than it once did.
If in doubt shoot me a model number.
Dec 05, 2012 | Toshiba Televison & Video
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Sony KDS 50a2020. Tv Seems to Dull. not a setting.
Two possibilities:
1. The lamp. When did you last replace it? They will dim over time and lose focus, clarity, brightness and sharpness. If it has been 18-24 months, and this is your main tv, consider replacing it.
It's a F-9308-860-0. They go for about $175.00.
2. Let's say you follow my advice, put in a new lamp and the picture is still dim, dark, dingy and fuzzy? Then you, my friend, need a new Optic Assembly. The thing your lamp shines into and the thing that gives you a picture to look at. They can fail or wear out for all sorts of reasons--too many for me to type out now. But, suffice to say, if you have recently replaced the lamp (less than 6 months) and are experiencing a drop in brightness, consider getting on the phone with Sony. Even if you are out of warranty, your set is covered against Optic failure until June 30, 2010.
Hope this helps.
Jan 21, 2010 | Sony KDS-50A2020 Television
Dull colorless pictures
Have you made any changes to the settings? Check the ISO, picture quality (should be at highest setting), white balance, etc. You could also go into the setup menu and find the "reset" entry to reset back to default factory settings.
Aug 27, 2009 | Olympus FE-280 Digital Camera
Dull/blurry picture
Sorry but You Don't.
Imagine taking a small Jpeg photo and blowing it up to Billboard size. It will be pixelized and dull.
Same with HDTV's. You can upconvert and adjust til your eyes turn blue, but you cannot take a Standard Def signal and make it look better by showing it on an HDTV. Some Standard Def material is better than others but ultimately what you see is what you get
Mar 23, 2009 | JVC LT-42X579 42 in. LCD TV
Dull
this is a common situation with the rear projection build. its a combination of the burn in effect and also, bad tuning. you can get a better picture by using the DVI option. rgb stream can give you a better picture as well. adjusting the sharpness can help sometimes.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ihave a sony KDF-E50A10 and the picture is fading
check the lamp timer in the menu page of the projector.it it is more than 1500 hours, it can be the lamp
alternativly u may also check the optical engine as it may be covered with dusty , hence resulting in dull images
Feb 06, 2009 | Sony (XL-2400) Projector Lamp for...
Dull screen on monitor model no.337n rev 8
restore u r system and new operatin system and click on u r display settings and change u r display settings lolz no pro if still pro occur mail me then
Oct 24, 2008 | Compaq Presario 700 470024-192 Notebook
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
