Question about Candy Washing Machines
Candy CFD 612 problem
After a wash, the waste water has not drained and attempting to switch off and re-program will not drain the water
  • 41 Answers
Have you checked the filter is the mach niosy if you pull the machine out lower the drain hose into a basin and see ithe water runs out if you tilt the machine backwards before opening filter you will have less chance of making a mess hope this helps
Posted on May 11, 2014
Lumpy816
  • 246 Answers
SOURCE: Washing machine will not drain
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Posted on Jun 15, 2008
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
  • 197 Answers
SOURCE: My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Posted on Sep 29, 2009
  • 35 Answers
SOURCE: washing machine not draining the water
the weater pump is bad replace....
Posted on Apr 13, 2010
My candy gof462 won't drain
pump blocked up
drum pump hose blocked up
some have a cage and a ball can trap anything and block
does it make draining noises ie can you hear the pump motor running
youll need to manally drain the machine and inspect the drainage
and also check your plumbing is ok to allow draingage {under the sink to the waste}
Sep 24, 2014 | Candy Washing Machines
Candy grand o evo error eo3
Not drained in time allowed - washing machine fails to drain water
·Check that filter is not blocked or obstructed
·Check drain hose is clear of any blockage or obstruction
·Check wiring to drain pump
·Check drain pump is not defective
·Check level sensor or switch
Check wiring to level sensor
Jun 04, 2014 | Candy Washing Machines
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
My Washer-Dryer Candy GO W465 does not start the programs.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Dec 31, 2012 | Candy Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
Water not draining
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
Oct 01, 2009 | Frigidaire Dishwashers
CBL 160 not spinning
itcould be speed control module, If the motor was gone it would not wash.
Mar 30, 2008 | Candy CBL160 Front Load Washer
Candy Dishwasher CS455M
i have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
Aug 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Washing Machines Logo
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
