Question about Electrical Supplies
My Robert shaw thermostat flashing RECO. What does that MEAN ?
  • 145 Answers
SOURCE: IS THERE A USER MANUAL FOR A ROBERT SHAW THERMOSTAT 9520?
YES YOU CAN GO ON LINE A GET THIS
Posted on Jan 08, 2010
SOURCE: error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Posted on Jan 10, 2010
  • 569 Answers
SOURCE: Our Robert Shaw thermostat 9520 just went blank.
Try replacing the batteries.
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Posted on Mar 06, 2010
  • 5481 Answers
SOURCE: what do two snow flakes on the left side of the
The double snowflake means that the second stage cooling is on. (One snowflake indicates first stage cooling.) This gives a greater temperature change in extremely hot conditions with than you could get with a single cooling medium and drier air in your home.
From the patent: A two stage cooling system in which the first stage's cooling affect is transferred to the second stage through direct contact with an oil-like material. The oil-like material is cooled by direct contact with water which has been evaporatively cooled. The oil-like material is then utilized to cool the air stream prior to the second stage evaporative cooling. The use of an oil-like material in the first cooling stage of evaporative cooling allows a relatively dry air stream to be produced so as to fully capitalize upon the evaporative cooling affect of the second stage cooler.
The second stage comes on if your system hasn't reached the desired temperature at the thermostat within a programmed length of time (5 minutes is a usual setting). BTW: Your system also has two stage heating.
I hope this helps.
Posted on Jul 07, 2010
  • 130 Answers
SOURCE: I have a Robert Shaw thermostat and it converted
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°?button for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°?button to switch the display.
Posted on Aug 11, 2010
Robert Shaw thermostat keeps resetting to 35 ambient temperature.
perhaps finding and reading the manual will help , here is a list from Google Robert Shaw Google Search
Oct 03, 2015 | Heating & Cooling
Repair robert shaw hot water heater gas valve I have a gas hot water heater with a robert shaw gas valve on it. I get no gas when i push on the red pilot button for lighting. I would like to fix it verses...
Yes you can get rebuild parts for the gas valve. You can go to partsguy.com to order them. Yo can also replace the whole valve for around $80.00.
Hope this was helpfull for you, let me know.
Thanks ,Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 10, 2010 | Shaw Robert RS-9420 Thermostat
Lost programingand instalation manuals
Here is a link to the complete user's manual for Shaw Robert RS-9420 Thermostat:
http://www.honeywell-thermostat.com/manuals/rs9420manual.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Shaw Robert RS-9420 Thermostat
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
We had a reverse problem with our Robert Shaw thermostat we left the thermostat setting at 52 so the pipes wont freeze we wore gone for a week, when we got back the up-stairs wore over 100 the thermostat...
Same thing happened to mine, it was replaced and the new one did the same thing about a year later. Needless to say it was no longer under warranty, which is no problem as I will not have another Robertshaw 9420 installed in my home. Very dangerous, especially if you are not home and it goes up to 99 or higher...
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
Error code on robert shaw 9600 thermostat
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Electrical Supplies Logo
52 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
