Question about Sharp R-1405 / R-140 Microwave Oven
Our base inside the machine won't go round - Sharp R-1405 / R-140 Microwave Oven
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Sounds like the motor has blown, I did have this once before and I found by taking the glass plate out and turning motor top where plate rests on by hand a few times it started to work again but it might be gone anyway, you might be able to get a second hand one but a new one is about 30 pounds so might be advisable to renew machine.
Posted on May 10, 2014
How to clean liquid under round grate oven base?
tip it toward the back and be prepared to wipe up a big mess
Apr 12, 2015 | GE Advantium 120 Convection/Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Should the turntable rotate? Mine is not turning
Yes the turntable must spin around to ensure correct heating of food.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Feb 09, 2011 | Neff H56W20N0GB 900 Watts Microwave Oven
Hi, we have a Bosch HMT8656GB integrated microwave (fitted in 2007) and in the last 2 weeks or so, the glass tray on the bottom of the microwave has stopped going round when the machine is in use, however,...
Hope this helps.
Feb 04, 2011 | Bosch HMT8656GB Microwave Oven
The turntable inside the microwave stopped rotating when using the microwave.
Hope this helps.
Jan 17, 2011 | GE JES2251SJ Microwave Oven
The glass plate inside will not rotate
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
How do I replace the water filter on a Whirlpool refrigerator model #gd5shaxlbo2?
Along the front base of the refrigerator is a round screw off cap. Locate and turn to remove. Inside is the water filter. Grab the tab on the filter end and turn CCW to remove. You may have to push in while turning on some models. Insert a replacement filter and turn CW to lock in place. Reinstall exterior cap. Its that simple.
For assistance, you can refer to any of the following websites for an illustration of you appliance:
pcappliancerepair.com searspartsdirect.com appliancepartspros.com
Enter your model number as "GD5SHAXLB02". The second to last digit is a "zero", vice the letter "O".
NOTE: You normally DO NOT have to turn off the water supply when changing out the filter.
If you have questions, please let me know. I hope this helps you.
Aug 15, 2010 | Microwave Ovens
Microwave sparked out now it does not work
You had something metal inside the microwave. Do you have a rack inside on a revolving tray? On my microwave, if the foot of the wire rack is not on the revolving tray, it will spark against the floor of the oven. Microwave will go around round pieces of metal - it will spark if it finds a flat surface. I dont think you did any damage to your machine but try to not do this again.
Sep 08, 2009 | Microwave Ovens
Microwave is arcing on the antenna blade.
Arcing is often the result of the cover over the magnatron (The thing that produces the microwaves) being aged, burned or damaged. If you look inside the oven, you will see a cover (usually square or round and around 3-5 inches across depending on the machine)made from a flakey silver plastic/fibre material. If this is burned or has a hole, it needs replacing and this will probably cure your problem.
Mar 13, 2009 | GE Microwave Ovens
Sharp R-1405 / R-140 Microwave Oven Logo
35 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
