Swan washing machine
Doesnt work on quick wash
  • 24 Answers
SOURCE: printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Posted on Aug 02, 2008
  • 240 Answers
SOURCE: my washing machine doesnt spin
check lid switch.
Posted on Jun 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
niki_p406
SOURCE: Wash machine pump doesnt work
my machine will not drain the water please help
Posted on Jan 03, 2012
User manual sw2051w
The SWAN (SWAN Laundry only) Help Line: 01189 252545 Monday-Thursday (9:00 AM-5:30 PM) Friday(9:00 AM-4:15 PM) You will need to tell them The Make: SWAN The Model:SW2051W
Good Luck! Swan is only warrantied in U.K. and Ireland!
Apr 23, 2016 | Sourcing Map Water Liquid Level Sensor for...
How to do a quick wash
You didnt state what machine you have but if your machine has a quick wash it will have a setting for that cycle every machine i delivered GE Maytag LG etc all had a quick wash setting on the dial if this doesnt help call manufacture to see if your machine has one good luck
Apr 22, 2016 | Washing Machines
Need manual for swan sw2011s washing machine??
You can contact Swan Customer services for white goods Call: 0345 610 4118 in the UK. They will be able to email you the manual in pdf format.
Hope this helps
Mar 13, 2016 | Washing Machines
The erore E33 little swan front loading w/ machine
I suggest that you search online for "error code e33 + little swan" you'll find most websites will offer some information.
Jul 11, 2015 | Washing Machines
My swan 2030b washing machine won't finish the cycle
This displays and error and it can be possible that the inlet flow is low, the inlet filter is clogged or the drain is faulty all of which can reduce the fill/drain timing and so causes an error..
Please remove and clean the filters and check the inlet flow pressure..
Mar 23, 2013 | Washing Machines
Does n e one swan Sw2010w manual please
Ask here, they are specialized on finding Swan washing machine manuals.
Jun 21, 2012 | Washing Machines
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Washing machine says its blocked
take the block off it and it wil work just fine.
May 14, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
