Question about Saws
How do I go about ordering a blade guard for an older benchtop miter saw.
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
  • 11 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
  • 323 Answers
SOURCE: Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Posted on Oct 31, 2009
  • 1383 Answers
SOURCE: Electric Blade Brake is not
Brake is controlled by the switch. There are two switches that can be used on your saw. One switch has only on/off, the other switch is on/on. On motor when pressed and on brake when released. The switch with brake does not last very long because the braking action is really just shorting motor circuit (short circuit). All motors can produce electricity. The brake action occurs by shorting motor thru switch. Electricity that motor is producing while turning forces armature to stop. Other brands use a resister in breaking system to absorbe current help switch last longer. Parts are available at www.toolpartsdirect.com Good luck
Posted on Sep 07, 2010
  • 127 Answers
SOURCE: I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Posted on Dec 31, 2010
Testimonial: "THANKS FOR THE ADVICE. THE BLADE HAS BEEN REPLACED."
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
How do I remove 12" blade from from dw705 miter
loosen the guard screw, UNPLUG tool first, move the guard out of the way, there is a spindle lockon the backside of the gearcase push it and slowly turn the blade until it engages and then remove the bolt, it is a left hand thread. DO NOT disassemble the guard, just loosen bolt and move out away from blade also you need to have the head in the raised position.
Oct 28, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Change blade
OK first raise the cutting head. Loosen the screw that holds the guard in place and move out of the way. Find the spindle lock on the right hand side of the gearcase and turn blade by hand (UNPLUG SAW FIRST) until it locks. With the wrench supplied with saw put it on the blade bolt and turn it clockwise to loosen, it has left hand threads, remove outer flange and blade. Let me know it you need any more help
Jan 24, 2009 | Black & Decker DW713 10 In. In. Comp Miter...
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Aug 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
