Question about Refrigerators
Maytag refrigerator unclog drip drain
Where is the drip drain located in a side by side Maytag Automatic Electronic Defrost Refrigerator, model MSD 2272veboo and how do I get access to the drip drain?
  • 1073 Answers
SOURCE: trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Posted on Apr 25, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
  • 531 Answers
SOURCE: Water from automatic defrost leaks into refrigerator.
drain clogged
Posted on Apr 01, 2009
aasc
  • 1606 Answers
SOURCE: How long is the defrost cycle?
Normal cycle is 28 - 32 minutes .
Posted on Sep 19, 2009
Testimonial: "Thanks, very helpful!"
heatman101
  • 43501 Answers
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
I HAVE A MAYTAG AUTOMATIC ELECTRONIC DEFROST CONTROL REFRGATOR MODEL MSD2272VEB00. EVERY FEW DAYS WATER LEAKED FROM UNDER THE REFRIGERATOR ONTO THE FLOOR FROM WHAT APPEARS TO BE AT THE FRONT RIGHT SIDE OF...
Inside of the unit is a drain hole that will drain out water to the drip pan. The drip pan is located under the unit and it uses the heat of the motor to evaporate the moisture that collects in it. The drain hole is plugged. Go on youtube and you can watch a video on how to fix it. Very easy.
Semper Fi,
Z
Apr 27, 2017 | Refrigerators
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Maytag MSD 2756 DE The freezer is working the the fridge is not getting cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water drip at base of freezer door at bottom!
Have you had a chance to locate the location the water inside freezer? There are many reasons for this to happen I just can not say it would be a defrost condensate drain blockage. Most times it is. Every 8 to 10 hours your freezer defrost and the water is surposed to follow a pipe or drain through the refrigerator to a pan below refrigerator where the warm air from condenser evaporates the water back to the air inside your home. That drain line sometimes slowly becomes blocked and then the drain hole becomes clogged with ice. Once that happens the drain needs to be cleared. I will try to help you solve this so for now I need you to see if water looks as if it came from rear of freezer. Placing photos on Flickr would be great! So tell me where you see it and yes we may need to pull a few things out. This is nothing a few towels, hair dryer hot water and Clorox and a wet vacuum cannot handle. Sea Breeze
Mar 20, 2010 | Maytag MSD2454G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
I have a Maytag refrigerator model # MTB2156BEB that leaks water from the bottom of the refrigerator door> I think the drain plug is clogged. I need to know where it is and how do I clean it.
This is most likely drain off water from the automatic defrost cycle.
There is a removable drip pan under the refrigerator that can get filled with lint and mildew and keep the water from evaporating properly. There is also a fan which pulls air across the condenser coils but also serves to help evaporate the defrost water.
Remove the drip pan and clean it out, clean off the coils with a brush and vaccum, and be sure the bottom fan is running. That should solve your problem with ZERO dollars out of your pocket.
Good luck. Hope this helps.
Sep 11, 2009 | Maytag Refrigerators
Sider by Side problem
If the "relay" is the bimetal clipped to the top of the coils , then the adaptive defrost timer is bad . Pt # 61005988 .This small electronic board , is located in the control panel .
Nov 02, 2008 | Maytag 23 cu. ft. Side-by-Side...
you cannot do this
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
could be afew problems, 1. no pwer out of thermostat 2. bad defrost board stuck in defrost mode.3 you hear any clicking at all? possible bad relay on compressor( removing it and shaking it generally gives it away). sorry not as easy check the plug
Feb 22, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
