Question about Dell XPS One Desktop PC - 20" HD Widescreen, Intel?® CoreTM2 Duo E4500, 8X Slot load CD/DVD burner
Why won't Xeon system hibernate? - Dell XPS One Desktop PC - 20" HD Widescreen, Intel?® CoreTM2 Duo E4500, 8X Slot load CD/DVD burner
    President:
  • 1,447 Answers
You should customize
Posted on May 11, 2014
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
System indicator lights won,t go off when i power off.
check whether the system is going on hibernation mode or not
Feb 01, 2013 | Computers & Internet
My sony won't shut down. it will only hibernate
Go to power options and uncheck hibernate mode.
May 10, 2012 | Sony VAIO TR2A Notebook
What does it mean if it's hibernating and won't turn on?
It means you need to remove the power cord, remove the battery,
put it back in, turn it on, and disable hibernation on your laptop.
May 11, 2011 | Samsung NP-NC10-WAS1US Notebook
The computer DELL Precision T3500 went hibernate, and I cannot figure out how to resume it
Hello
To work around the hibernation (S4) problem, temporarily turn off the Hibernation feature. To do this, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click Power Options.
  3. Click the Hibernation tab.
  4. Click to clear the Enable Hibernation check box, and then click OK.
Hope this helps, if so do rate the solution.
Jan 10, 2011 | Dell Precision T3500 Computer Workstation...
Should I Leave my PC in sleep mode after use?
Go green & use hibernate instead.
Well, actually a lot also depends upon what is the duration of you not using the system between breaks. Hibernate anyways is quicker than a normal boot process. I would highly recommend hibernate.
Sleep - is a combination of stand by and hibernate. Be default most of the newer system will write the memory info into hibernation file & put your system to stand by mode. After certain period say 2-3 hours your system will go into hibernate mode. (these are standard settings & unless you keep coming back in 15-20 mins you should use hibernate & contribute towards environment too)
Oct 07, 2010 | Computers & Internet
My system won`t come up after hibernation
go to the link
http://www.hp.com/#Support and select download drivers and softwares...in step 2 type in you products model number and click go now select your operating system.now in
the following window look for BIOS and
under BIOS click on Winflash for HP
notebooks.now in the following window
click on sp45070.exe and after that you
will get a box here click on run.now just
follow the onscreen wizard and click on
options like next and continue.once the
process is complete your system will
automatically shut down.just turn on the
system and it should work fine after
that.
Jan 21, 2010 | HP Pavilion Tablet Notebook
Dual E5345 Xeon -Upgrade?
Hi there.
If you note down the make and model of the motherboard you will be able to check to see if you can upgrade to better processors and which type of processors the motherboard supports.
If you want me to source the info please post the make and model of the board.
Thanks for using FixYa!!
May 22, 2009 | HP Hewlett-Packard Intel Xeon Quad-Core...
Won;t Hibernate
Sony laptops are infamous for these kinds of problems. You very likely have another Sony program running in the system tray which is trying to control all power functions in a "smart" (in other words, defective) manner, and this is conflicting with and resetting your OS's normal power settings. Try to find this program on your laptop and run it and check what it thinks it is doing. You might also have a problem with the actually writing of the hibernation file on your machine due to any number of problems (low disk space, conflicting file names, corrupted administraive priveledges for whatever program thinks it is doing the writing). I'd suggest uninstalling the SONY power management software and then using the stuff the operating system provides. It might not be good, but it at least works kind of, and consistently.
The changing status of the hibernate settings you describe suggest to me that another program is changing them to try to be "efficient".
Last resort - disable hibernate; it doesn't work very well on Sony laptops even at the best of times.
Nov 16, 2007 | Computers & Internet
Dell XPS One Desktop PC - 20" HD Widescreen, Intel?® CoreTM2 Duo E4500, 8X Slot load CD/DVD burner  Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
