Question about Refrigerators
Parrot ice 2405 slush machine. One side leaks refrigerant very slowly. Where do I charge it at?
  • 833 Answers
SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
aborcass
  • 2651 Answers
SOURCE: thin ice
before trying anymore repairs , you should chemically clean the uit, this will definalty improve performance., undercahrged might also be issue
Posted on Apr 12, 2008
watugot
  • 290 Answers
SOURCE: Freezer not cooling enough
Jimmy,
Check the condenser coil and clean it if it is dirty. It is located under the machine behind the grill in the front, or in the back of the machine near the compressor depending on the make and model. Also make sure that the condenser cooling fan near the compressor is working. If the refrigerant is not cooled properly in the condenser the system will run hot and not cool properly inside the freezer.
If this does not help your problem, you will probably need a refrigerant technician to check the system. A rule of thumb for refrigerator repair, Freezer working but Fridge warm = airflow blocked inside the unit somewhere, Fridge cooling but Freezer too warm = refrigerant problem. This is usually a major problem that will cost too much to repair than is cost effective . Check your owners manual for warranty information. Look for coverage for the "sealed system". This is usually 5 yrs but can go much longer depending on make and model.
Let me know what you find out. Please post the model and serial numbers if you have any more questions and I will try to help.
Thanks, Mike
Posted on May 11, 2008
  • 409 Answers
SOURCE: Kitchenaid side/by/side refrigerator Model KSCS25INSS01-Auto defrost happening often and ice machine not producing ice
hi there,
the icemaker is not making ice due to the fact that the valve solenoid may need replacing.
check the water line into the icemaker, to make sure that you don't have a water leak.
the reason the fridge is running is due to the fact that it's trying to remove as much warm air out as possible.
i would have a technician look at it.
Posted on Sep 17, 2008
  • 409 Answers
SOURCE: Water leaking from ice/water dispenser
hi there,
you may have a kink in the water line leading to the icemaker. the leak is due to warm water entering the icemaker itself. i would also check the water valve in the icemaker itself and ice actuators or paddles to any breakage.
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
I have a sunsip slush machine and is not freezing, and machne is running for nearly 6 hrs
if the mix is cold but not freezing, you may be low on refrigerant or the timer is in defrost (if it has that feature). if it's warm, either the solenoids are not opening or there is no refrigerant. check the exhaust. if there is little air flow, clean the condenser coils (air intake). if it's cold, the compressor is not functioning or no refrigerant. for low or no refrigerant, you have a leak. take it in for repair
Jul 21, 2014 | Kitchen Appliances - Others
Left side of Bunn Ultra "ice" mode is in lower case but right side "ICE" mode is in upper case?
upper case means it is still trying to slush. lower case means it has reached designated slush thickness
Jun 15, 2014 | Bunn Margarita Machine Ultra 2 Slush...
I have bunn slush ultra 2. 1 side freezes 1/2 way, like slushy a little bit but still watery, other side is only chill. both are set to 16 thickness.
make sure both say "ICE" on the display. press the snowflake buttons on the front to get it there. also, make sure you are mixing the product properly. if still an issue, you may have a small refrigeration leak that should be looked at by a professional
Aug 26, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Parrot ice slushie machine Compressor comes on,
Liquid gets very cold but won't freeze
Jun 10, 2010 | Freezers
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
hi there,
Sep 04, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
