Question about Dell Office Equipment & Supplies
Printer not activated error code-41
Its a DELL Photo 964, every thing is connected but it just wont print! Please help!
  • Joel Rodriguez
    Joel Rodriguez May 15, 2014
    Hi Johnny Boy, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?did you install the driver and software for the printer?
checkitright
  • 1362 Answers
SOURCE: Dell Photo 964 - unsupported cartridge
How is it plugged first of all, did you set it up as a dell printer in add printer? try adding it as a HP printer since they are HP printers with the Dell name.
Posted on Oct 04, 2007
coolfixya
  • 82 Answers
SOURCE: code error 41
Error 41
The head drive voltage has not been turned from Low to High within the specified time.
Check:
Carriage ASSY
Main PCB
Print head unit
Power supply PCB
Posted on Feb 28, 2009
leethedeuce
  • 4472 Answers
SOURCE: Dell Photo Scanner / Printer
Unfortunately on their website it isn't listed as supported by windows 7. Also when a new operating system comes out there is always a lot of issues in the beginning. I have seen quite a few windows 7 problems of this nature. My first question would be did you run the setup in compatibility mode for windows vista? This would be the first thing to try.
Thank you,
Lee
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: printer not activated error code-41
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Mar 01, 2010
pineworks
  • 4041 Answers
SOURCE: dell 964 printer error code 1203
Ok can try this
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
What is causing a Phone Line Error when I go to fax?
Do you have the fax set to the proper setting? Check that and verify.
Jul 13, 2017 | Dell Photo 964 All-In-One InkJet Printer
964 Dell printer will not connect to wireless network
As for the 964 printer, ues you can make it wireless by using a Dell Wireless Printer Adapter 3300 or some type of wireless print server. To install the drivers for the 964 printer, you will need to post in the Dell Printers Forum, as the printer drivers on a Vista machine are a little tricky to install but I have my 964 printer working with a 3300 , (thanks for Rick dell forum)
Jan 10, 2010 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 964 All in One Printer
first u see cartridge is ok or u can install a new cartridge then aling from both the side first u give print of aling page and then scan the aling page i think this well solve the problem
Aug 19, 2009 | Dell Photo 964 All-In-One InkJet Printer
I can't print in color on dell photo 964
try to uninstall ur driver and install it again
Jun 07, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 printer error code 1203
Ok can try this
or
Apr 16, 2009 | Dell Photo 964 All-In-One InkJet Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
Print Head Error
You need to replace the printheads. You will have to call Dell in order to get the printheads and instructions for your machine. Oh and please take a moment to give this solution a fixya rating. Thanks! :c)
Dec 27, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 964 all in one printer
During the photo printing wizard, in printing options window, choose the printing preferences button. Once you are there, choose the maintenience tab located on the top of the screen. Choose the clean print cartridges button. Hope it works!
May 21, 2008 | Dell Photo 964 All-In-One InkJet Printer
21 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
