Question about Roundup 4-Gallon Backpack Sprayer 190314
Roundup 4 gal.backsprayer wont build up pressure
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: How to mix roundup to kill weeds
6 fluid ounces of Roundup (12 tablespoons) per gallon of water.
Posted on May 02, 2010
jyackle5
  • 8197 Answers
SOURCE: how much roundup to 1 gal water forwatering can use
6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
Posted on May 29, 2010
jyackle5
  • 8197 Answers
SOURCE: How much roundup to 1 gal. of water?
1 1/2 oz per gallon
Posted on Jul 01, 2010
How do you get the top off a Roundup 2 gal. sprayer?
Release the pressure, push the handle down andturn it to the left.
Aug 15, 2014 | Roundup 2 Gallon Multi-Use Sprayer
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How much roundup to 1 gal water forwatering can use
May 29, 2010 | Roundup ScottsRoundUp 0394560 PT...
May 02, 2010 | Roundup ScottsRoundUp 0394560 PT...
Roundup 4-Gallon Backpack Sprayer 190314 Logo
83 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
