Question about Event Planning & Celebration
ADJ sweeper I just purchased a pair of Sweeper Beam Quad LED. I want to set them up using a master/slave configuration with sound and using a wired remote. I've assigned one as the master and one as the slave and connected with a DMX cable. When I hit the stand by button, lights come on both units but the slave won't tilt(rotate). If i switch them, the same thing happens. The master will tilt(rotate) but the slave won't. I started messing with functions and I got it to work. I unhooked everything and plugged it back up to make sure everything was working and the issue came back. The master will rotate but the slave won't. What am I doing wrong? Please help!!
sgregg
  • 133 Answers
SOURCE: nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
Posted on Sep 18, 2007
  • 176 Answers
SOURCE: wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Posted on Jan 20, 2008
SOURCE: Brush roller will not turn when I star to sweep.
maybee there is hair in it, do u know how to fix a psp that doesnt read games
Posted on Jan 15, 2009
SOURCE: Sony 400 CD players are connected, but won't recognize each other
try setting the slave to CD3
Posted on Nov 10, 2009
  • 740 Answers
SOURCE: Both headlights do not function on low beam but
there is a bad connection in the switch or the multifunction switch is bad
Posted on Feb 09, 2010
Sc400 seats are not getting power and are stuck in furthest back position
The sweeper. A sweeper can help direct adjustments, since he is usually the deepest field player.------------------------------------------------------------------------------------
Original Launch X431 Master
Mar 06, 2013 | Lexus SC 400 Cars & Trucks
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Mar 02, 2013 | E-Machines T2892 PC Desktop
My pool filter works fine until I try to plug in the sweeper and then it will not sweep at all. Is this a sign I need a new pump and filter?
Stop plugging sweeper in or you will burn out the pump.
If you are plugging sweeper into same circuit as pool pump, and pool pump is ON at the time and pump stops running, the sweeper is drawing too much amperage for pump to work.
If this is the case, you are burning out the pump by continuing to do so.
It sound like you need to add separate circuit for sweeper.
That being said, I am totally uncertain what equipment you are using or the amp load or breakers.
For complete answer at fixya, more information is needed.
What are you plugging into?
What size breaker feeds the circuit?
is this 120V or 240V?
What size wire do you have?
What information shows on nameplate of each pump and sweeper?
If you are uncertain of these things, or unfamiliar with electric wiring, then consider calling electrician.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 14, 2011 | Intermatic T10404R - two 220 time clocks...
I accidentally Uninstalled by software while trying to update to a newer version. How do I get it back?
Ascertain the type of program that has been uninstalled from computer to determine methods to reinstall. For example, discovering that spy sweeper program was uninstalled makes possible to attaining the same program or alternate. Spy sweeper program once acquired on disk becomes reinstall able or makes adjustment modification attainable with encounters experienced on computer. Ascertain that type of software to determine whether acquirable from retail markets either at physical store location or online internet purchase. In situation that least has the program available as replica requires purchase however similar programs perform like spy sweeper on computers. Visit a computer retail store to ascertain the resource that makes effective resourcefulness.
Feb 24, 2011 | Webroot Spy Sweeper (spysweeper) for PC
I want to uninstall spy sweeper but I can't. I get a runtime error. How can I uninstall?
download a software called youruninstaller... and install
uninstall spy sweeper using this software..
your problem ll surely get over
May 11, 2010 | Webroot Spy Sweeper (spysweeper) for PC
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Purchased new pc w/windows 7 os. installed spy
In order to solve this problem you have to solve this problem
you have to uninstall Spy Sweeper.before that you open taskmanager and in the process tab,click on the respective process of spy sweeper
and stop it.Then you could uninstall it from your pc.
Then install Spy Sweeper from your cd.
Feb 07, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Purchased a Hoover Mach 3 upright sweeper which gives off a odor
Return it immediately and run the unit with a store rep as witness.
Dec 30, 2009 | Vacuums
Event Planning & Celebration Logo
245 people viewed this question
Top Event Planning & Celebration Experts
Bosse Photos
samiya_jahan
Level 1 Expert
Are you an Event Planning and Celebration Expert? Answer questions, earn points and help others
