Question about Dishwashers
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
I have tried opening and closing the door, over and over, pushing on the center of the door, canceling and resetting cycles and still nothing.
  • 4 more comments
  • ty2010 May 10, 2014
    Is it for certain the water is on to it?
  • Jonelle Ropolo May 10, 2014
    Yes the water is on. It has been doing this off and on for a couple months.
    It could be a switch or control going out from dampness that functions again when it dries out. They have really slow logic in them and get hung up if buttons are pushed too fast. If it has a resume cycle button, press that and wait for 4-5 seconds before pressing cancel, otherwise you may be stuck with the unplugging.
    What do you mean by unplugging please?
    Usually installers will install an outlet under the sink that the dishwasher will plug into, if not turn the breaker off a few minutes then back on and try again. If resetting like this works it means there's more likely a logic problem than a failing part.
  • Jonelle Ropolo May 11, 2014
    We will try tonite and if this fails I will be back with more questions. Thank you for your help.
    Sergeant:
  • 304 Answers
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
Posted on May 11, 2014
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
markevans
  • 148 Answers
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
Posted on Dec 28, 2007
markevans
  • 148 Answers
SOURCE: Kenmore dishwasher locks. after cycle, can't open door
bad solenoid or controller
Posted on Dec 21, 2007
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Kenmore Elite dishwasher: not doing anything.
turn off power an back on / if no change remove the toe panel and the tech sheet will be there . it will tell you what the code is and how to correct most .. mm hope this helped. pls leav feed back.
Dec 07, 2009 | Dryers
Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
May 13, 2009 | Kenmore 15939 Built-in Dishwasher
Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Jul 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 665-15962 Elite 8 yrs old
Won't start nor drain. what could the problem be? please help.
Apr 02, 2008 | Kenmore 15872 Dishwasher
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
174 people viewed this question
Top Dishwashers Experts
Owen Barnes
