Question about Technics Audio Players & Recorders
How do I attach a SLB technics record deck to a technics DV250 stereo system
They were purchased separately. I have plugged them together but I have no sound.
    Scholar:
    New Friend:
  • 54 Answers
If you plugged it into the aux or vcr input and have no sound, you probably need a phono amplifier first. Signals from turntable are very low in comparison to other sources and need to be boosted up to normal levels first.
Posted on May 11, 2014
What compatible turntable on the market for Technics stack system.SA EH670
If the amp has a left and right phono jacks for a record deck, you can use any turntable you want. Though you will need a separate power plug socket for the deck.
Oct 09, 2014 | Technics Audio Players & Recorders
How do I connect and hear a technics SLB210 turntable to a DV250 sound system
The signal output from the turntable is very low and needs a special input which most modern sound systems no longer have.
You will need to connect your turntable to a preamplifier.
The output from this preamplifier then goes to the auxiliary input ("AUX") of your sound system.
A good starting page to look around for a turntable preamplifier is here:
http://www.amazon.com/gp/richpub/syltguides/fullview/21PCGJR9SBLQP
May 10, 2014 | Audio Players & Recorders
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
Can I use a microphone through a technics rs m216 tapedeck?
The tape deck was designed for stereo recording using two separate mikes, one for left input and one for right input
Jun 28, 2012 | Technics Audio Players & Recorders
I purchased a used Pioneer CT-660 dual stereo cassette deck, recorder but have no instructions
Look for an owners manual on Hi F Engine. They can be found at times on line.
Jun 11, 2012 | Pioneer Audio Players & Recorders
Manuals For Technics
The manuals for these are on paper not electronic files. Is there are particular problem you are trying to solve?
Dan
Jan 06, 2010 | Technics Audio Players & Recorders
How can i connect a record player to my stereo.
you have to get a pre amp that will boost the 5mv phono signal to 300 millivolts to drive the aux inputs.
it also has to have RIAA equalization,as all albums have a -60db curve 1khz and down to reduce the stylus travel of the record groove.
without the equalization,the grooves would have a 4" modulation.
if you amplify the record player signal flat gain,it will have no bass at all,just the way it was recorded. radio shack used to sell a 9v powered unit back in the eighties,see if you can find one.
most new stereos do not have a phono input.
Sep 01, 2009 | Technics SC-DV290 System
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
TECHNICS SC-DV250
keep an eye out on ebay.
Dec 31, 2006 | Technics SC-DV290 System
41 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
