Question about Maytag MAT12PD Top Load Washer
WHy won't my washer finish its cycle?
My Maytag MAT12PDBAW won't finish its cycle. The cycle started fine (whites) with hot water but is not moving past 15min on the rinse cycle. Washer is coin drop and is fully hooked up with electricity and hot/cold water. It will not reset even after unplugging. Does anyone know the issue or how to manually reset the machine?
    Problem Solver:
  • 15 Answers
Check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
Posted on May 13, 2014
Testimonial: "Thank you. The lid switch is fine after double checking. I was able to reset the cycle by initiating diagnostic mode, but the problem still persists. The washer gets hung up with 15 minutes left on every cycle. The only diagnostic code I get is "d7 Last fill was slow". Could this be a water pressure issue or a timer issue?"
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
pride applia
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
SOURCE: CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP
I JUST HAD THE SAME QUESTION FOR A CUSTOMER REQUEST, I TALKED TO THE TECH SUPPORT AT MAYTAG AND THEY EXPLAINED THAT ALL YOU DO IS UNPLUG THE CONNECTOR CC FROM THE PRINTED CIRCUIT BOARD THEN SCROLL WITH THE CENTER BOTTOM BUTTON, TILL YOU SEE 600 DISPLAYED. (600 IS ZERO COINS, 604 IS 4 COINS, 608 IS 8 COINS, ETC.) THEN RECONNECT THE CC CONNECTOR AND PUT IT TOGETHER, SOUNDS SIMPLE ENOUGH. IM GONNA GO TRY IT
Posted on Oct 15, 2010
  • 4340 Answers
SOURCE: the cold water flow will
Clean or replace the cold water valve. you are a flood hazard.
Posted on Feb 23, 2011
What does the HC code mean on the Maytag Bravos Quiet Series 300 mean?
You can fix it. Your hot and cold water hoses are reversed on the water valve on the washer. Switch them around you should be fine.
Sep 08, 2014 | Washing Machines
Why won't my washer finish it's cycle?
First attack is the lid switch- make sure it connects when closed- you can bypass with a jumper until replaced. After that the water inlet valve. If asking for cold rinse the washer will just sit there waiting to fill. confrim cold water at the valve by pulling hoses or if there is cold at other times like warm wash - you can feel it while filling. There may be a blocked in-line filter so check the external hoses and valve too.
May 16, 2014 | Maytag MAT12PD Top Load Washer
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Apr 14, 2009 | Washing Machines
Maytag washer will not rinse on the white cycle. is it the timer?
you must know that because it sets there and dose nothing???if so it has to do with water[its calling for it and its not coming so it keeps waiting,cant move on till sattifies the water level switch].set timer at start of load and check water setting temps .dose cold come out when set cold only also same hot.ihope thats a bit of help.God bless ,tom
Jan 04, 2009 | Whirlpool GSC9455 Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Maytag MAT12PD Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
