Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Jandy Lite 2 heater won't ignite FL4 code?
I have a Jandy Lite 2 that has an FL4 Code. Igniter is new. Heater works for a while then shuts down and won't ignite. It makes one click noise then displays FL 4 code. Any thoughts on how to solve
  • 4 Answers
So, you replaced part R367100 (Igniter)? This part if very susceptible to failure if touched. I would inspect and/or run a continuity check to make sure it has non cracks. Does it glow red when you attempt to start the heater? Remember, that is the how it ignites the flame, by getting red hot.
If it glows red hot, but does not light then I'd do the following testing in between;
Check that the inline fuses on the igniter aren't blown,
Check if the control board is sending a charge,
Check the flame sensor for gunk build up. Unfortunately to replace the flame sensor look like you have to purchase a whole new burner assembly to get a new flame sensor.
I also believe there is a toggle switch on the front door. It may need to be depressed before the system will ignite.
Posted on May 12, 2014
  • 2 more comments
  • mike
    mike May 13, 2014
    Thanks The Igniter was replaced one year ago. Flame sensor is new. I inspected the igniter. its intact but appears to have brown spots on it. When it lites the igniter glows. When it won't ignite the igniter does not glow. It woks intermittently. Perhaps it is the igniter?
  • Warren Christopher
    Warren Christopher May 15, 2014
    Yes, I'd replace the ignitor. It's one of the easiest and cheapest solutions. If that works, it's time to figure out why both your sensor and ignitor when out. Have you checked for leaks or excessive condensation on the heating coils? I had a cracked manifold and it caused a world of hurt. Good Luck and let me know how it goes.
  • mike
    mike May 17, 2014
    Thanks Replaced igniter same problem. The only way I can get the heater to ignite is power it down for 5 minutes then turn it back on. Any thoughts
    Warren Christopher May 19, 2014
    Well Mike, I'm out of suggestions. To clarify. When you turn on your heater the ignitor glows red. Then the gas comes on and the burner assembly lights. It works for a while then, stops and displays an FL code. Then if you wait 5 minutes you can do the whole thing over again. If it lights, burns, clicks, flashing FL, turns the entire until off and you have to wait 5 minute. Then you've triggered some sort of "breaker" safety system. I don't know enough about the electronics or safety systems to help. Good Luck
2 Suggested Answers
  • 36 Answers
SOURCE: jandy lite 2 heater model
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Posted on Aug 31, 2011
I have the FL4 error code. Replaced igniter and checked the fuses. Still doesn't light
FL4 is related to the flow in your heater, you need to check first if you filters are too dirty, remove then reset breaker and try again if it go away it was your filter being too dirty, if it doesnt it is most likely the PressureSwitch on your heater.
Aug 17, 2015 | Jandy Laars Lite2 Pool & Spa Heater -...
Had an FL4 error code and in-line fuses were blowing, replaced the R0367100 igniter (old one missing the tip) and fuses, but still blowing the 2 fuses and getting the 04 code.
make sure the wiring is correct then take fenwall off turn around to see if burned spot where ignitor wires go in sometimes the ignitor will take out the fenwall shorting it out so you will keep going through ignitors
Sep 15, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Reset code 4
According to pages 34-38 of the installation and operations manual, FL4 is one of the codes that does not automatically reset itself after the fault is repaired. To reset the controller after an FL4 (or 6 or 7), press the "Select" button until the heater is off, wait a minute or two, and then press "Select" to put the heater into "Pool" or "Spa" mode. The heater should then go through the ignition sequence and function normally. NOTE: The manual also says that an FL4 code should be fixed by a professional.
http://www.zodiacpoolsystems.com/~/media/Zodiac/Global/Downloads/H/H0248900.ashx
Jun 20, 2014 | Jandy Lite2 LJ 400P, 400,000 BTU Heater,...
Readsfl4 surfaces ignition problems
check the fuses going to the ignitor if ok ohm out ignitor to see if shorted or open should ohm out at 78 ohms if bad replace
Jun 05, 2014 | Jandy Laars Lite 2 Pool Heater 250000 BTU ...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Fl 4 code
fl4 = Igniter Failure
A. Igniter circuit is open: Check fuses on igniter wires
B. Element has a fine crack in it: Replace igniter
C. Igniter fault: Replace igniter
Apr 09, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 heater gives FL4 display
F is an igniter failure. Try the following. A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. C. Replace igniter.
Jul 10, 2009 | Jandy Laars Lite2 - 125,000 BTU Propane...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
240 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
