Question about Maytag Neptune FAV6800AW Top Load Washer
MayTag FAV 6800 AWW TL washes but stays in a slow spin mode, sometimes does a fast spin to dry clothes but not dependable it shows no codes and is not off balance have replaced the door lock assembly left side, right side is OK. I am very puzzled have no service reps here on a small Island must DIY only please help! It seems to just sit in a slowly spin cycle continuously and not count down when entering spin cycles?
  • 41 Answers
Is the drain pump ok .ie if the water does not get out in the proper time the mach will think it is still full and will not speed up
Posted on May 11, 2014
  • blueh2os blueh2os
    blueh2os blueh2os May 13, 2014
    Yes it drains, I took off the back of the consol and found a service instruction doc. I tried several times to get into the diagnostic mode with enviro and Spin only, just can't seem to enter that mode. I have tried and tried no luck but I have after several attemps got this machine to go through a wash completely it is very tempermental. I can hear it spin at hight speeds sometimes and it throws out the water when it does spin. If it were to be the clutch would it not ever go into high speed if the clutch was bad? I am not sure what to try next I'll trouble shoot this to death as it is too costly just to replace items that may or may not work and some are so expensive a new machine is in order. I like the machine it hasnt been through a lot it looks great. I believe only about 6 years old. oh I get no codes to tell me what is up. Thank you for the input.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: I am looking for the
You can get the manual on the link below.
http://www.ajmadison.com/ajmadison/itemdocs/PDF_MAY_FAV6800A_user.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 09, 2010
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Tl FAV6800A stuck in wash cycle
Hello rockhead255 ,
I'm an owner like you and will try to help.
Error code 10 states Unbalance or cabinet hit detected during final spin, which prevented the spinner from exceeding 500 rpm
Did you notice if you took some large tub swings as the washer tried to spin up?
I suspect a Clutch malfunction. Pump the water out of the tub with the Board Output Test with the drain pump in service mode. With the wash tub empty open the lid and see if you can rotate the wash basket CCW with one finger. You mentioned “”Tub does not turn by hand””. Is that in the CCW direction?
You should be able to rotate the wash basket with your pinky finger with very little force. The wash basket will not rotate CW. What amount of rotational resistance do you detect in the CCW direction? With the error 10 reported I would drop the clutch out of the machine per my step by step procedure at this post. Try the One-Way roller clutch bearing clean up and re-lube as I discuss in that post and see if you can restore the machine to normal Spin operation. Once you drop the clutch out of the machine we will have a better feel for the issue.
You can try the TDS check in the SM but I feel it is a Clutch issue at this point of troubleshooting. Good troubleshooting using the machines diag code listing.
Post back if you havd need additional questions or help.
Rich
Posted on Sep 28, 2009
Testimonial: "Thanks for the answer, I will try these when I get home this afternoon."
dh1200s
  • 335 Answers
SOURCE: Wont spin with clothes
Common problem with this model I own it. Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair? Read thru this post for the details of what is involved. Post back with any questions. Rich
Posted on May 03, 2009
SOURCE: maytag neptune tl washer spins during wash cycle
lid switch is bad
Posted on Feb 15, 2012
Maytag washer is sometimes out of balance and clothes are sopping wet when spin cycle ends. Washer is balanced on the floor.
1ST thing put less clothes in washer each time
second ck to see that drain hose is not obstructed from draining out the chamber , ive seen fabric lint get stuck inside the drain valves and slow and eventually block them off
last thing to look at
temp defeat the lid lock switch and or watch it spin thru window , your looking for the speed it spins at (should be a blur !!) , if its slow and not steady in rate but instead sort of gets slow/fast/slow/fast this could be an indication that your tub drive system isn't working well , this depends on a large bit of things working properly , but could be as simple as a worn out drive belt too.
Feb 03, 2017 | Maytag Washing Machines
I did the field service mode test
contact the manufacturer . you are the repairman .
Oct 26, 2015 | Washing Machines
Excess water in clothes at end of spin cycle
SOUNDS LIKE THE MOTOR COUPLING TO ME.
May 15, 2009 | Maytag Washing Machines
May 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptne fav 6800 aww does not fill wiht hot water. works fi
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
CLOTHES STILL SOAKED AFTER SPIN CYCLE
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag Neptune FAV6800AW Top Load Washer Logo
98 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
