Question about Technics SC-DV290 System
How do I attach and play a technics record deck to a technics stereo system?
They are both technics but they were not bought as one unit
5 Suggested Answers
Gletkin
  • 49 Answers
SOURCE: Hi, I have a technics stereo system from 1986.
If the turntable is belt driven you may have a stretched and slipping belt that needs replacement. This seems most likely and is simple to fix. You will have to lift off the turntable to see the mechanism beneath. It may be held on by a nut or clamp. A web search for the model name and "dirve belt" may yield a replacement.
If it is driven directly by a motor without a belt, the motor is probably dying. Replacement more involved, expensive, and hard to justify, unless you're really into vinyl.
Posted on Aug 06, 2009
  • 63 Answers
SOURCE: how do i connect technics turntable model SL-QD33
Have a look on the back input panel of the sc-dv290. Check for a "PHONO" input. If there is no phono input it will not play turntable. If there is: then plug it the turntable in and switch the SC-DV290 to PHONO mode.
Another way would be to purchase a "phono preamplifier" from ebay: Hook the turntable into the phono preamplifier, and the preamplifer into the SC-DV290 AUX input.
Posted on Feb 26, 2011
gstrider
  • 54 Answers
SOURCE: How do I attach a SLB technics record deck to a technics DV250 stereo system
If you plugged it into the aux or vcr input and have no sound, you probably need a phono amplifier first. Signals from turntable are very low in comparison to other sources and need to be boosted up to normal levels first.
Posted on May 11, 2014
welsh534
SOURCE: Manuals For Technics
want to learn to play
Posted on Jun 19, 2015
HOW DO I SET UP MY KENWOOD MINIDISC RECORDER
A MiniDisc recorder would plug into your stereo system just like a regular old cassette recorder would. Line out from deck to line in/play on receiver/amplifier and Line In from deck to "record" / tape line out from amplifier/receiver.
Insert MiniDisc, select Source and you should be ready to hit 'Record' and then 'Play' to start recording.
Mar 04, 2016 | Audio Players & Recorders
May 10, 2014 | Technics Audio Players & Recorders
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
I have a Technics Stereo tape deck (M224) that I am ready to toss out, use as a boat anchor or a paper weight but found your site. When I try to play a tape, the tape drive works fine but instead of the...
Open up the unit and locate the long silver component that is activated by the record switch. Flush this out using electronics cleaner and work it back and forth a few times. This might clear it up. What is happening is that the unit is caught between play and record modes. Cleaning this switch assembly often clears this up.
Update this with your results.
Dan
Jul 21, 2010 | Technics RS-TR373 Single Cassette Deck
The manuals for these are on paper not electronic files. Is there are particular problem you are trying to solve?
Dan
Jan 06, 2010 | Technics Audio Players & Recorders
My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Nov 18, 2009 | Panasonic Audio Players & Recorders
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Record player works but no sound from speakers
I've had this happen before, and it is caused by your ground wire not being hooked up. Depending on the type and age of turntable, it will have an additional wire (the ground), that needs to be hooked up to either a screw or some sort of opening similar to your speaker wire hookup. That should take care of the problem. If you don't have a ground wire coming out of your turntable, I don't know how to help, other than figure out how to ground the turntable.
Sep 29, 2007 | Audio Players & Recorders
Technics SC-DV290 System Logo
27 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
