Question about Dryers
Whirlpool supreme dryer
What year did they make these?
    Problem Solver:
  • 15 Answers
If you can get me model and serial # i can get you close. its located around the opening where the door is
Posted on May 13, 2014
Whirlpool supreme LER7646EQ2 won't heat up
The heating element is no good. They break after years of use as they heat up and cool down over and over, they wear out. The part is cheap and yes it is easy to replace. Turn your dryer around, and take off the screws to a short piece of metal that has "vents" in it. It should be sticking out a bit compared to the rest of the dryer back. normally 2 or 4 screws holding it there. You'll see the element. Just pull it out, take it to the appliance shop or Sears and get another element. Go home, stick it back in there and reconnect the panel you took off. Cheap part, simple fix...you'll be surprised how well it heats after that.
Jun 09, 2012 | Whirlpool LER5636P Electric Dryer
Whirlpool supreme gas dryer will not heat up. model# LGR7646EQ3
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Whirlpool LGR7646E Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool Supreme Dryer rumbles while turned on then stops mid cycle. When I push the start button I hear a buzzing noise, then a click and then silence. After the dryer sits for a while, it will start...
Chances are it's the drive that drives the belt around the drum, or the motor is on its way out. Have a technician inspect the belt/belt drive system as well as the motor.
Jan 29, 2010 | Whirlpool LER4634J Electric Dryer
No heat in whirpool supreme dryer
Check the PILOT-LIGHT. And be sure the gas is reaching it.
Oct 25, 2009 | Whirlpool LER5636P Electric Dryer
Been working fine and now won't start.
Hi friend.
it mostly be the motor problem itself or,,,,see anything stucked below tub it will also cause problem.check it
thank u,,,,,,,,,
May 03, 2009 | Whirlpool LER7646E Dryer
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Dec 30, 2008 | Whirlpool LGR7646E Dryer
Whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
Oct 05, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
Top Dryers Experts
