Question about GE Spacemaker Over-the-Range Microwave
I have a 1994 GE JVM240wl002 microwave. After running it about 8 mins it stopped working. The lights, vent, control panel all work but it won't start up. Any ideas on what might be the problem?
  • 151 Answers
One of the door switches bad, magnetron overheated or bad, capacitor for magnetron weak or bad or problems with the controls. Less often and more involved a bad triac, less involved the internal fuse blew but would be caused by one of the other problems.
Posted on May 10, 2014
SOURCE: GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Posted on Apr 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave (jvm1740dm1bb) - Control panel inop
That model number is not quite right. I'm going to assume it's JVM1740DMBB01.
(If that's not right, please check the tag inside the oven & reply back)
The membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
The part number you need is WB07X11040 and you can find helpful exploded view diagrams and order this part here for $107.00 (compared to $164.75 from GE!)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM2070CH02 microwave stops after a few seconds
This is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same type of problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jun 05, 2009
  • 92 Answers
SOURCE: GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
Posted on May 30, 2010
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
GE spacemakerXL microwave JVM1650 w touch screen Hi speed not working on external vent fan
It seems like the control panel is malfunctioning. The censorfor external vent fan may not work due to faulty control panel. You need toreplace the control panel, so that microwave will work properly. Replacing anERC is not a difficult repair and can be accomplished by the average do-it-yourselfoffer. Hope this will help you. Good Luck.
Aug 06, 2011 | GE JVM1650 1000 Watts Microwave Oven
I need to replace the control panel on a GE spacemaker 2.0 microwave. Model is JVM2070SK01. How do I remove the power vent to gain access to the control panel?
They're our favorite supplier.
Aug 22, 2010 | GE JVM2070 Microwave Oven
The second under cabinet light went out with a pop, and the vent fan went out with it. Is there a fuse for both somewhere? The turntable motor and light and fan still work. Will th vent fan come back on if...
There is a varistor or thermostat switch mounted on the wall behind the control panel. I unpluged the leads and shorted them together. the fan and lights started working again. I got another microwave off freecycle.org for parts. I noticed a lot of sites tend to point to the control panel for a $36 to $100 board repair. Don't fall for it. H.G.
Jan 03, 2010 | GE JVM1660 Microwave Oven
Control panel for GE microwave
The control panel module is different from the membrane. Unfortunately these modules themselves are usually very expensive, perhaps 1/2 the cost of a new microwave.
Sorry.
Oct 06, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Over-the-Range Microwave Logo
126 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
