Question about Drills
My drilling machine 26mm active pro brand. i am using drilling one hrs ok after running problem hammering mode stoped only running not working for machine not proper working in hammaring mode.what problem.pls help me
  • 151 Answers
Sheared hammer pin, stuck hammer or failure of a bushing or washer. A sharp tap with a rubber mallet in an area not likely to be damaged can sometimes free stuck hammers, if not it's a disassembly.
Posted on May 10, 2014
  • 2712 Answers
SOURCE: hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Posted on Aug 27, 2008
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 583 Answers
SOURCE: When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Posted on Aug 15, 2009
nova2nv
  • 197 Answers
SOURCE: drill works fine but wont engage hammer
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Posted on Nov 18, 2009
duane_wong
  • 6826 Answers
SOURCE: my bosch hammer drill 1199
Sure, it could be bad brushes or a broken connection inside the drill.
Posted on Aug 03, 2010
Bosch gsh 10c is not hammering
Likely the hammers are broken inside the drill.
Oct 07, 2016 | Bosch Drills
Why did my hilti te 805 just stoped working when drilling can anyone help
A real Hilti brand means it has got the operating hours on it.
Only service a complete kit of components , this machines are have most liquid oil lubrication (most of the times a very expensive) Turmopol oil and special poor tolerance bearings HILTI and DUSS are high quality machines , Duss machines i prefer some higher then Hilti because of the long last service for more then 40 years old machines they have all te parts for them , but not cheap Unfortunately.
If a hammer stopped working like Dewalt all the parts are simple to get. most of the times a broken powercable or a brush that have become in protected state autostop , Dewalt hammer in the States is not the QS quality of Europe i know . but quality like the old ELU machines instead of black and Decker ,
Nice machines and are not fast leak , but it could also after a long period.
Jul 14, 2014 | Dewalt D25330K 2KG Sds Plus Demolition...
110 v comb drill does not engage to hammer setting
You don't say which model or make. could be just the selector.
Oct 19, 2012 | Drills
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
Nov 18, 2009 | Dewalt DC925 Cordless Drill
I Have a Craftsman Pro 1/2 in Hammer Drill . The Keyless Chuck is $50 plus ship and Hand. puts it over $70. Is there some type of off brand or can any replacement chuck work
Any replacement chuck will work as long as it is the right thread size and made for a hammer drill. I would try and find a JACOBS chuck for this. You should be able to pick it up locally.
Nov 12, 2009 | Craftsman Drills
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drills Logo
62 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
