Sharp tv lc-40le240e aqius, can not get BBC channels on tv - but when I move to another room with tv get BBC . But not itv ? Tried retuning on all levels puzzling ???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
You must have an issue with the cable box in that room
Posted on May 12, 2014
  • 1214 Answers
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Posted on Feb 16, 2009
dave1645
  • 834 Answers
SOURCE: I have retuned my Panasonic HD TV as per your
both of those channels are in anolog, so on todays tvs they are going to look that way, sorry , something you have to live with if the cable company puts them on a digital channel they will look better but not HD quality
Posted on Sep 30, 2009
Obertelli
  • 3006 Answers
SOURCE: HAVE GOT A SWISSTEC 15 INCH TV BUILT IN FREEVIEW,
The model number would usually be on the back of the TV but in this case it's immaterial as Swisstec appear to have had a very brief existence. Their website no longer works (skymediamanufacturing.com, no connection to Sky satellite tv) and the few products which have their brand name on all seem to be at outlets like ALDI and Makro which often specialise in clearance lines and bankrupt stock.
First, check that your missing channels haven't been shifted to 801, 802 etc. This is happening with some equipment and it's just how some slightly incompatible equipment handles the retune.
What you have said about your aerial system does not eliminate the possibility of an aerial fault; as you're running multiple items off one aerial I'd fully expect it to be a high gain aerial, but this does not necessarily mean that it's a wide band aerial. In addition, each time the signal from a single aerial is split there is typically up to a 10dB loss (around 60% each time). Regular analogue reception equipment can cope with this far better than Freeview receivers as the analogue signals are vastly more powerful than the digital ones. One of the most important UK transmitters puts out a 100kW (i.e. 100 000W) analogue signal along with an 800W Freeview one making the analogue signal 125x stronger at the transmitter and far weaker further away.
Realistically, you have limited options. Most Freeview receivers have an onscreen menu in the digital tuner which has a signal strength and quality meter for each channel. If most of the channels have a middling signal with good quality then your reception is most likely ok so look at the aerial cable at the back of the set to see how long the plug into the back of the tv is. If it's longer than about 2cm then it probably has an in-line suppressor fitted onto the end of the plug. Usually there's a marking of either 6dB or 10dB on the suppressor. Remove any suppressor and try retuning.
If that didn't work then check as much of your aerial system as possible paying special attention to the plugs and splitters. No plug should be showing any bare wire, and the external screening braids must not be touching the internal signal wire. You'll probably have to undo each plug to check for this and remake any shoddy work. If you have aerial splitters which are the push together variety then check the connections are tight. Also consider replacing them with the screw threaded F-terminal splitters which all professional installers use. These cost very little more than the useless things sold in most DIY stores and general retail outlets but hugely reduce signal losses. I've posted an online address of a supplier at the end of my post, but you can also get them from your local Maplin store usually at extra cost.
If you have an amplified aerial then try disconnecting the amplifier. These are often inappropriately fitted and cause digital signal meters to show the confusing message of a strong signal with poor quality. A good quality weak signal can be successfully amplified but a poor quality signal requires a better aerial installation.
If you have eliminated all doubt regarding your aerial then the fault is most likely with the receiver itself. The official advice is to try retuning but you've almost certainly done that. There is a list of equipment known to have problems with the retune (see second web address) but it's not comprehensive and misses out minor brands like Swisstec. Clearly you cannot contact Swisstec and they are in no position to rectify the problem themselves any more. Under these circumstances your only remaining option is to buy a new external receiver from around £20 and connect it to your tv as if it never had an internal receiver.
Note that the UK Sale of Goods Act was recently amended to allow purchasers up to six years protection against goods which are not of "satisfactory quality" (replacing the earlier term "merchantable quality"). You've had your tv for eighteen months and the tv itself still works, but as a super-budget unknown brand it's doubtful that you could press your rights regarding the failed Freeview receiver.
Sorry this is not the easy fix you were hoping for but I hope that it's been of some assistance.
1st web address. Supplies and excellent general aerial advice.
http://www.aerialsandtv.com/ampsandsplitters.html
2nd address. List of known incompatible equipment. Not really of use to you but at least shows you're not alone...
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Posted on Oct 09, 2009
Testimonial: "Thank you for replying so quick and for the indepth help that you have given. Fingers crossed"
dave1645
  • 834 Answers
SOURCE: I have a samsung LCD TV LE27S7 32 in I think and
cable company moved them do a rescan of your channels
Posted on Nov 18, 2009
  • 458 Answers
SOURCE: i have tried to retune my tevion lcd 1507id
These will have been rolcated to a different channel number. You can select the programme guide & scroll through all the channels until you find thier new location number, then you could either take note of these new numbers or go into the set up menu where you can re-arrange the channel numbers back to 4/5 etc or set them on your favourites listings
Posted on Dec 08, 2009
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
Why can I not receive ITV channels
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
What is wrong with my tv
Sep 03, 2014 | Televison & Video
Proline tv
Caroline , have you tried to retune your TV
Sep 05, 2013 | Televison & Video
Cant get any itv channels after retuning my new tv because of bad reception on itv channels.its a new aerial and the tv in other room ok its HITACHI 26ins L26HPO3U
in the manual i noticed a note about the active antenna and it should be showing not active when standard antenna is used.i also tried channel scan instead of first time installation which i tried a few times.so i dont really know which worked,just kept trying.
Jan 04, 2010 | Televison & Video
Ldc tv with built in freeview wont tune to bbc 1 bbc 2, retuned 20 times still no bbc 1 bbc 2 . before i did retune i would receive bbc wales post code OL16 2RR North west
Buy a digital antena,or roof antena recieve better siginal,get everythings.Tries reset to factory setting retune again will get BBC1,BCC2 well get it back.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I cant get bbc 1 2 or 3 on my sharp aquos LC-37XD1E I HAVE TRIED TO RETUNE ON AUTO SERCH AND ALSO ON MANUAL
cable company is doing alot of moving of channel more that likely they moved them of the tvs quam tunner there is anoth wave od moves in dec may it will get put back on that tier
Nov 18, 2009 | Televison & Video
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have retuned my Panasonic HD TV as per your instruction which I printed out. Fine with ITV, Channel 5 and 5. BUT BBC 1 AND BBC 2 are fuzzy. Can you help please?
Sep 30, 2009 | Panasonic Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
