Lg 1.5 tr split ac capilary replaced.size 5.0 ,length 1 1/2 ft. gas charging done.ac running for 20 mints.after 10.7 amps incressing and of the compressor over heat.i will replaced 50+4 running capacitor.but again same problem .what is the problem.how it solve the problem
  • 21 Answers
The best practice when replacing a cap tube is to replace it with the identical size and length of the old cap tube. Also, you must run it in the same way, if the cap tube was soldered to the suction line in any area then the replacement should also be soldered to the suction line. The old cap tube should have been stretched out, measured and gauged with a cap tube gauge. If you just went by load, it appears your cap tube is the wrong size, should be a #4 or .064ID and not a #5 .028ID. This is just based on some cap tube sizing charts I looked at assuming you have a single cap tube and not a multi circuit evap. Other than the cap tube the symptoms point to a system that was overcharged, dirty condenser, condenser fan motor not running. If you have a way to check suction and discharge pressures this will be the best way to see what is going on.
Posted on May 10, 2014
Error code 16 coming up on my treadmill 956i
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Treadmill error code 16
Corrective Action
Precor Error 16
Precor c954i error 16
Corrective Action
Precor Error 16
Sep 08, 2012 | Precor C954i Commercial Treadmill
My split air conditioner compressor fail is it due shot pipe length total pipe length less then 1.5 mt.unit is 1.5 Tr and room size is 160 sq ft.using steblizer.
A/C compressors fail because the system is overcharged, not enough charge in the system. Compressor can also fail if it's started before it has a chance to cool down first.
May 28, 2011 | Heating & Cooling
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
MTD yard Machine lawnmower,17hp Briggs And Stratton engine. Runs for about 15 or 20 minutes and stalls. It will not start again until I recharge the battery over night. Then only runs again for 15 or 20...
yes it could be
check your battery 1st , then check the stator a/c output
• 10 or 16 Amps DC regulated for charging
battery
• Two black leads (C) from stator
• Yellow connector (D) with two pin
terminals
• Two yellow leads (E) to regulator-rectifier
(F)
• One red lead (B) from regulator-rectifier
to red connector output lead (A)
• 10 and 16 Amp systems use the same
stator, color coding and regulator-rectifier
• Alternator output is determined by the
flywheel alternator magnet size
The stator and regulator-rectifier are the same
for the 10 and 16 Amp systems. The system
output is determined by the flywheel magnet
size.
Test Alternator Output
1. Temporarily disconnect stator wire
harness from the regulator-rectifier.
2. Insert RED test lead (A, Figure 28) into the
V ω receptacle in the meter.
3. Insert BLACK test lead (B) into COM
receptacle.
4. Rotate selector to AC Volts position.
5. Insert RED (A) and BLACK (B) test lead
probes into output terminals (D & E) in
YELLOW connector (C). (Test clip leads
may be attached to either terminal).
6. With the engine running at 3600 rpm, the
output should be no less than:
• 20 volts - 10 Amp System
• 30 volts - 16 Amp System
7. If No or Low output is found, check for
bare wires or other defects. If wiring
defects are not found, replace the stator.
voltage depending on alternator type and magnet size
then check the regulator / rectifier , make sure it is grounded properly
make sure battery earth lead is good
i suspect loss of bat voltage is letting the afterfire solenoid close off the main jet
let me know model and type codes off engine & i will try help further
cheers
Aug 29, 2010 | Briggs & Stratton Garden
MOD on a window AC
The capillary tubes are your metering device, without those, and the length of the tubes are determined by the design of the unit and tonnage.
On bigger units we use expansion valves to do the same job,
Apr 04, 2010 | Heating & Cooling
NEED CAPILARY TUBE. WHAT SIZE HOW LONG. TRUE
have ready a correct make and model number and call 1st source at 1-800-392=3939. if u can't get it there, who knows. plz rate me.
Jul 27, 2009 | True 23 cu. ft. / 651 liter Commercial...
How to mesure the lenght and size of capilary,is the lenght and size important
how to mesure the length and size of Capilary 1/4 Hp Compressor R-12 volt 220 ho
Apr 22, 2009 | Kenmore 94499 Refrigerator
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
