Question about Apple iPhone Smartphone
When i put my iphone's ringtone sound to the highest notch and when someone calles me it just vibrates. i dont know why. ive been working on it for hours but it still wouldnt work. please help me?? <<33
  • 39 Answers
There is a switch above the ringer volume. This switch turns the audible ringer to vibrate. Make sure to switch it to on. (If you are using a soft case, many of those are bad about hitting this button to off.)
Posted on Jun 23, 2009
My ringtones have stopped when someone calls me there is no sound just the vibrate noise
Raise your phones ringtone volume. You probably accidently put your phone on silent.
Aug 01, 2014 | Cell Phones
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
    Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
    Don't worry about a reset or hard reboot. You won't lose any data or settings.
    Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
    My samsung c3050 will not let me recieve incoming calls. it just beebs when someone trys and rings me
    change the ringtone, or go to sound settings and change not to beep but play sound . if you put vibration and sound the vibration starts firts and the cames the sound in all samsung phones
    Mar 09, 2011 | Samsung C3050 Cell Phone
    Ring tone vs vibrate
    There is no option to turn off the ringtone. You're not doing anything wrong. The only way to turn off the ringtone is to use the volume button to turn the sound off or to vibrate, or using the hot key (#) to go to "Vibrate Only Activated". I hope this explains what you wanted to know.
    Aug 19, 2008 | Samsung SCH-u340 Cellular Phone
    Samsung a737 is the model
    Here is a quick run down on that and a link to the PDF manual that will tell you everything you need to know.
    This is for a Verizon Samsung u700 mobile phone.
    1.From the main screen, press OK MENU, use the right navigation key to highlight SETTINGS & TOOLS and press OK.
    2. PRESS (BUTTON 4ghi) SOUNDS SETTINGS.
    3.Press (button 1@) CALL SOUNDS. or Press (butoon 1@) CALL RINGTONE to get new ringtones from "GET IT NOW" (GET NEW APPLICATIONS) or choose from the pre loaded ringtones.
    4.Press (button 2abc) CALL VIBRATE to turn Call Vibrate On or Off.
    5. Press OK to save settings
    Aug 10, 2008 | Samsung SGH-E630 Cellular Phone
    Ringtone volume problem
    do you have it on vibrate along with the ringtone? sometimes they place the vibrate under the speaker so you can barely hear the ringtone if it's on vibrate..
    Jun 28, 2008 | Samsung SGH-D600 Cellular Phone
    Iphone wont ring
    Did you check to make sure that the "mute" switch on the left side of the iPhone is turned off (if you see an orange dot, it means mute is turned on). It may not be vibrating either because in main Settings - Sound - you haven't turned on "Vibrate" when on Mute.
    I thought my iPhone was broken until someone pointed out this to me.
    Feb 16, 2008 | Apple iPhone Smartphone
    Phone will not ring
    Thanks, The orange dot on my phone was showing as well. That fixed the problem.
    Jan 21, 2008 | Apple iPhone Smartphone
    İPhone not ringing
    you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
    cheers!
    Nov 15, 2007 | Apple iPhone Smartphone
    Apple iPhone Smartphone Logo
    235 people viewed this question
    Top Apple Cell Phones Experts
    David
    Marvin
    Marvin
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
