Question about Kenmore 22422 Top Load Washer
All of the cycles work on my 70 series washer, but it will not auto advance on any of them. Is this the timer?
  • 79 Answers
Your timer motor stoped working, timer is around $60. Sears stores has them, they are fairly simple to replace, if you try make sure you UNPLUG THE WASHER BEFORE DIGGING IN.
Posted on Jun 23, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 70 series washer pausing for long interval through cycle
BAd timer, replace the timer in your system andall will work great, go to repairclinic.com to order your parts
May 16, 2009 | Washing Machines
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Frididaire Washer Works but wont auto advance
hi thanks for the question The problem appears to be the timer change it thanks THE APPLIANCE DOC
Aug 27, 2008 | Frigidaire CWS3600AS Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 70 series washer and it wont stop
the timer it bad. there is a contact inside it that has gotten stuck. replace the timer to fix problem
Nov 25, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Robert Rankin
