Question about John Deere 300 / 316 Hydrostatic Tractors Part Manual
My tractor is turned to the right and the steering wheel will not let me turn it to the left. What is it?
  • 151 Answers
Usually a frozen kinkgpin or bent linkage.
Posted on May 10, 2014
5 Suggested Answers
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
  • 5 Answers
SOURCE: JD 2030 power steering failure
either the steering arm in the bell housing on the right side of the tractor is striped or the colume is broken internaly. the is asuming that all tie rod ends and the bell crank are still atatched.
Posted on Jun 25, 2009
  • 2427 Answers
SOURCE: John Deere Diesel 720 1957?
sounds like a malfunctioning power steering motor.. or it could be the rack. remove the motor and see if the rack turns properly(without ant sticks or glitches) if it does replace the motor.
Posted on Apr 26, 2011
  • 3911 Answers
SOURCE: Steering, The right front axle
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Posted on Aug 08, 2011
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
I have a 42" craftsman tractor... when you turn all the way to left the wheels get stuck... can I adjust anything?
What happens when you turn right? Does it turn as sharp as it used to? Almost sounds like the steering gear teeth have slipped and now it is steering to far to the left. You'll have to check the steering sector gears at the bottom of the steering column.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Turns fine to the left but will not turn right past going straight.
check your steering linkage on the front side by that right hand wheel, is it bent or being restricted? Even check up and down on the steering wheel column itself.
Aug 13, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman Lawn tractor - When turning to the left the Left front wheel turns much farther then the right front wheel does on a hard right turn. Almost perpendicular to the tractor. Busings are brand new....
I've noticed this on other Craftsman and MTD mowers. The ones with the one main steering rod from the steering wheel to the left wheel and a connecting rod from the left wheel to the right wheel. I think that since we are advised to mow in a counter-clockwise direction, they design the mowers to turn tighter towards the left. It's in the design just like you suspected.
Apr 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Soft steering 2007 Simplicity Prestige 27hp tractor.
have you checked your fluid level
Aug 13, 2009 | Garden
Won't turn right
Had this on my riding mower. The steering rod going to the wheels from the steering assembly was bent. Take it off and straighten it and re-install.
Aug 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Jun 16, 2009 | John Deere Tractor Side Screen...
Turns left sharply, barely turne right
The problem is either that there isn't enough range on the steering gear in the right direction, enough length on the steering drive rod (going to one front wheel), or a bent tierod (connecting the 2 front wheels) or worn tierod bushings.
Most likely is the tierod. I do not like how these are designed so for my own tractors I make one using tierod ends available from tractor supply company, grade 8 bolts and steel tube with a 3/4" inside diameter. A bit of measuring and welding later the steering is better than new.
May 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere 300 / 316 Hydrostatic Tractors Part Manual Logo
53 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
