Question about GE JVM1650 1000 Watts Microwave Oven
How do i replace the door on a ge spacemaker microwave?
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 96 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Broken handle on GE Spacemaker XL1800 microwave
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
My GE Spacemaker (JVM1331) will not turn off when door is shut. Have had to unplug unit. This unit is 15 years old.
one or more door swiches need replacing maybe be three in all but likely one is the cause not sure which one without testing with electrical meter
Oct 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven - need to replace auto vent door
IF YOU KNOW NOTHING OF ELECTRICS ESPECIALY M/WAVES LEAVE WELL ALONE THET CAN BE ===LEATHAL===I MEAN LEATHAL.
Oct 04, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Door to GE spacemaker is loose. EWill only run if
Have the door of your microwave adjusted and screw is tight, so you won't be holding it.
Oct 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Broken bezel/trim on door of GE Profile Spacemaker XL MICROWAVE.
You need to call GE customer care and order the trim you need. Make sure they will ship the replacement guide with the part. Before you do that however, carefully inspect the door to see if the old trim can be easily removed. This is important! You must determine that the door/gasket will not get out of alignment in the process. If this happens, dangerous microwave energy can escape.
Ray
Nov 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
