Question about Panasonic NN-H965 Microwave Oven
How do i change the turntable motor on a sears 72163259301
  • 28 Answers
Go to the bottom of the oven - they have several side-by-side holes that when you cut through the little bit of material between the holes, allows you to create your own door - inside should be your turntable motor - Again this is a standard type location - Commercial units may not have turntables, but the 'stirrer' is instead located below the plain table on which you rest your food
Posted on May 14, 2014
The turntable stopped on my sears microwave. how do i fix it?
This problem is very common.
The turntable motor is defect or its gear mechanism worn out.
You'll need to have the turntable motor unit replaced.
May 10, 2014 | Microwave Ovens
How do i change the turntable motor on my sears microwave
Most microwave ovens have a door on the bottom of the oven to access the turntable motor - I am not familiar with a Sears in particular, but if the door is not already cut free and held with a screw, it could be like a Panasonic Microwave whereby you have to cut through side-by-side holes to create your own door on the bottom - then you should be able to access the motor and remove it's screw(s) and wires - It the door is one you had to make, then they will have it created so you have tabs to line up, but you need a screw to hold it in place
May 10, 2014 | Panasonic NN-H965 Microwave Oven
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
How to install turntable motor in kenmore 72169072900
You can find helpful exploded views and find parts by entering your full model number (72169072900) at the Sears Parts Direct Web site.
Remove the glass tray and turn the oven on it side to get to the bottom base plate.
If you look at the diagram titled "base plate parts" you'll see the access panel on the bottom in the center that has to be removed to get to the turntable motor screws.
On some models, you have to cut the metal strips holding the panel in place, then during reassembly use a screw to reattach it. In some cases, the cover has to be rotate 180 degrees before reinstallation.
You then unplug the connectors on the turntable wires, then remove the screws holding the turntable motor, gently lift it out and also ease the turntable off the motor shaft.
Jan 29, 2013 | Kenmore 62642 / 62644 / 62649 Microwave...
Sears Kenmore Microwave Model 401.80086700
Hello
Youcan see that turntable at the down side there is a screw which is missing because i m also having a same problem but now once you change that screw which is losse it will work
Thanks & Regards
May 24, 2009 | Kenmore 80412 Microwave Oven
Turntable on Kenmore Elite will not turn?
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
If you don't have your owner's manual, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
That's where you could also order any needed parts and find handy exploded parts views.
Jan 04, 2009 | Kenmore 63792 Microwave Oven
My Kenmore Elite Microwave model # 721-66469500 turn table stoppe
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
Nov 29, 2008 | Kenmore 63792 Microwave Oven
The glass dish that goes around - makes a strange noise
You may have a bad motor orplastic coupler.
Nov 22, 2008 | Kenmore Microwave Ovens
Turntable not turning all the time
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the motor cover off with snips, then use a screw when reassembling it.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Microwave Ovens
Turntable problem 80802
It looks like the mechanism on those models consists of a glass tray a roller ring, and a motor, but in the diagram I don't see a coupler... The coupler may be built in to the motor or tray. You can visit http://www3.sears.com/ and enter your exact model number - like 721.80802### - not just 80802. The parts lists and exploded view diagrams for the turntable parts should be located in the section "Interior Parts 1". Those will help you figure out what part(s) you need, which you can order online or by phone or in any Sears store. If you need more help, repost with any new details you have. I appreciate your rating of this reply.
Nov 13, 2006 | Kenmore 80809 Microwave Oven
Panasonic NN-H965 Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
