Question about LG Heating & Cooling
Air conditioner remote set time - LG Heating & Cooling
2 Suggested Answers
jdvillanueva
  • 2098 Answers
SOURCE: Air conditioner on it's own
Radioshack.com Contact cleaner
Ebay.com Contact cleaner
Posted on Aug 27, 2011
Unitherm air conditioner remote skips the heat mode
Halo
Remove your battery's for at least for 10 sec and reset the remote if still the same problem then you should replace it just be sure that the universal remote is compatible with your unit.
regards
May 26, 2016 | Samsung Indoor Split Type Room Cold Air...
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
We have a Sairon Air conditioner and we don't have the manual. How do we set the time on the remote control so we can use the auto start function? Also we are wondering how to use the heat...
Press clock. time will start flashing. Now press < or > until required time. Then press Set.
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position.
Jan 16, 2011 | Friedrich QuietMaster SS12L10 Air...
Hello I need instructions on setting up the timer using the remote control for a RES 24C1 air conditioning unit. Hope you can help. thanks
There are 2 systems in timer set up. You follow as per your remote supports.
1. Set clock first. and then by pressing timer on make the time you need on. and same for off by timer off.
2. Press timer on which starts with 00.00. By pressing you can select how many hours after you want to switch on from current time and same for timer off. Is it useful? Write.
Dec 11, 2010 | Fujitsu 24C1 Air Conditioner
How do you set on and off mode on air conditioning
Use the remote to enter the timer to switch off - OFF timer setting and the On timing after setting the clock on the remote
Once this is presetted the unit will continue to work shut of in the thermostat settings and fully cuts off power in the set off time.
later the set will come back in the set on time and work till the thermostat setting is reached.
Aug 29, 2010 | LG Heat cool Window Air Conditioner
Power went off while ac was running. Now ac will not run. Has a wall mounted controller with a hand remote.
if it is a mini split you have to set date and time on remote before unit will work remove batteries from remote and start over
Sep 29, 2009 | Dometic Rooftop RV Air Conditioner
Air con model no CS-1273KR
Okay, the question WAS asked just over six years ago, but I see that it hasn't been answered yet:
To set the time:
1. Open up the "door" in front of the remote.
2. Press the little round button beneath the "UP-DOWN" button.
3. Set the time using the ?P-DOWN" button.
(How I know? I double-checked it with my remote, which is an A75C377).
The manual does not show you how to set the clock; only how to set the time. Manuals are available online - do a Google Search...
Oct 13, 2008 | Panasonic CS-A12C Air Conditioner
Heating & Cooling Logo
10 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
