I have a good quality picture. vertical rainbow lines & white mass on lower right side of screen prevents me from viewing entire screen. what can be done to get rid of this?
Color patches due to strong shock or vibration cannot be eliminated by anyway, to CRT type TVs. Gopakumar Gopalan Google
SOURCE: Polaroid 40 inch tv (TLX-04011C) Picture is
its the ribon cables from the lcd patern bords on top there is 2 of them normaly its the right side that goes bad but in your case its the left there is only 1 way to fix it
you have to replace the lcd screen panel with the 2 pattern bords on top
SOURCE: Can it be fixed?
The panel may have been damaged but remove the back from the unit and reset all connectors.
SOURCE: vertical rainbow on right hand side of screen
Sounds like u have a crack in your LCD panel. Not much u can do except order a replacement panel. If u press on the panel it will rainbow more. Only thing u can is replace it.
SOURCE: Vertical lines through the right side of the screen
Sorry sounds like you have a bad panel Try changing picture format if the lines don't dissappear or change bad panel
SOURCE: 3" vertical line down right side of tv
Answer depends on model number of set which is not indicated here.
