Question about Dual XDVD210 6.2" Touchscreen DVD Receiver
No factory plug from stereo
The factory plug for stereo is gone replaced with plug from after maket stereo of unknown origin how to hook up to that plug
I Hooked up my new stereo and cant get any sound. I put the factory Bose back in and the sound works. Hooked up my new stereo to another car and it has sound. Can anyone tell me Why im not getting sound...
If you had a "Bose" sound system - Factory installed - it should have and Amplified System - which means the original stereo will supply power to the Speaker Amps - that is the circuit that didn't get connected and why there is no sound.
I hope that resolves your issue
Thanks
Feb 22, 2015 | 2002 Nissan Pathfinder
I want to connct a cd player in car1995 honda how to connect wires like plus and minus wires
If you still have the original stock radio plugs it's best to buy a wiring harness that will connect to the factory plugs. Then the wires are all labled to hook up any cd or radio.It's called a stereo connector made by scosche check it out.
Sep 11, 2013 | Cars & Trucks
The stereo plug was cut out of my 89 geo metro and im trying to hook a cd player up. i need the color code for the factory harness going to the stereo
this is the year way before the radio color standards.
so get it off the metro forum/
in google i type, "metro forum" no qoutes and see..... yah.
or get it off mitchels
or alldata dot com.
or buy and FSM on fleabay.
Feb 14, 2013 | 1989 Geo Metro
Display will not dim when headlights are on.
There is an extra wire on the back that should be hooked up to the car for that function. If your car does not have this feature for the original factory stereo then you'll have to find some wire in the dashboard that comes on when you turn on the headlights. If you bought a car stereo adapter when you installed the new stereo to plug it directly into the factory plug then there should be a wire for this purpose. If you connected all the wires correctly then again, maybe the feature wasn't available on your car.
Oct 04, 2012 | JVC KD-HDR61
How can i replace 1991 maxima radio system?
The original radio is a BOSE system and it has a buit in amp. So if you replaced the deck you need to replace the speakers all so. Don't cut the wires to hook-up the deck buy an addapter KIT. It's not just the stereo that runs though that harness the factory alarm does all so and that will cause you problems. Anyway back to the stereo you need to add an amplifier and problem sovled.
Jul 23, 2012 | 1991 Nissan Maxima
I have a jvc kd-s27 i am very familliar with hooking up stereos,i have tripple checked everything and i am still getting no sound from the speakers i can plug in the original stereo and sound works...
Its because u probably u have factor amps like my car that has infinity sound system I used the wire harness adapter that plugs into the factory harness u need to plug the wire that is alone and not in the factory plug into the power antenna/remote wire sould fix that issue
Feb 18, 2011 | Car Audio & Video
Hardwire color code diagram for 1998 Honda
Just buy an after maket radio plug which is cheap at wall mart .It also has the wiring diagram for the radio.speakers listed
Oct 07, 2009 | Pioneer CDJ-1000 CD Player
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Radio comes on but i cant hear any music
You may be connecting this stereo into an amplified system. If the original factory stereo worked with the factory amplifier, your stereo is not turning the amplifier on. If you purchased the aftermarket wire harness that mates to the factory stereo connector, hook up the "Amplifier Trigger" wire, this wire is usually blue.
Oct 16, 2008 | Pioneer DEH-P3500 CD Player
Aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Sep 15, 2007 | Car Audio & Video
Dual XDVD210 6.2" Touchscreen DVD Receiver Logo
32 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
