Question about Whirlpool WED5850SW Dryer
The Whirlpool dryer light works, tub spins when pushed so the motor is not seized, but when I select the heat and cycle and push the start button, there is a very soft click sound but nothing happens, what could be the problem? Fuse? Circuit board? Other? Can it be easily and cheaply fixed?
    Master:
  • Whirlpool Master
  • 753 Answers
You may have the thermal fuse blown. It is not re-settable and they usually blow because you have a venting issue. A crimped or blocked vent line. It is the long white piece next to the blower housing in the back of the dryer. Always unplug the dryer before servicing it.
Posted on May 10, 2014
  • 151 Answers
The start windings are out in the motor or the momentary start switch on the motor is bad.
  • 262 Answers
SOURCE: My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Posted on Jan 08, 2008
kachbibi1
  • 979 Answers
SOURCE: Dryer motor/heat does not start
This may sound dumb, but it happened to me once. I turned off the breakers, then turned them back on and it worked. Sounds like you have done all the other stuff. The last thing that the other fellow put on the site, makes sense as well. Check the breaker first and the connections.
Posted on Jan 17, 2009
  • 708 Answers
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Posted on Mar 13, 2009
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
  • 23 Answers
SOURCE: Heating element heats up, but dryer will not spin.
Since you stated that the heating element is heating up I believe it rules out the thermal switches.
When you push the start button does it make the motor make any noise? Maybe hear the motor humming? Two things to check for are Broken Belt or Bad Motor:
This requires common sense and since you are going to be bypassing the safety features you need be CAREFUL.
First, with door open, manually press in door switch to by-pass door safety, then press "start", try to manually start the dryer by spinning the drum by hand, If you hear the motor humming but it does not start spinning on it's own; most likely it is a broken belt which can be changed without much difficulty for less than $15 bucks. NOW if it then continues to spin on it's own GET YOUR HAND OUT OF THERE and close the door; you have a bad motor and even though it started it needs to be replaced. A motor for that is available for just under $100 bucks and is not to bad to replace, I would recommend replacing the belt at the same time since you will be in there. Good Luck!
Posted on Apr 29, 2009
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
Model # LEW0050PQ - The dryer heats and runs for designated cycle time, however does not spin. Will spin if you manyally "push start" it however will get stuck when cycle spin reverses. HELP!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jun 25, 2010 | Whirlpool LEW0050P Electric Dryer
When dryer is started the timer can be heard and if the door switch is activated, the heating element will heat, but the drive motor does nothing. belt is ok
try holding the door button, have someone push the start button and you spin the tub at the same time. If it starts, it is most likely the start capacitor on the motor. If it does not start, look at door button, start switch/button, and lastly, the timer.
May 01, 2010 | Whirlpool ET8CHEXSQ Dryer
Whirlpool Calypso dryer GEW9868KL2
It is one or two things. Motor start switch or the motor itself.
Aug 11, 2009 | Whirlpool GEW9868K Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Apr 29, 2009 | Whirlpool LEQ7030KQ Electric Dryer
What goes on in the dryer as it is being used?
customer selects cycle
customer pushes start button
motor starts, motor switch closes and turns on element or igniter
depending if electric or gas
tub turns and heat dries clothes
thermastats cycle during run not to overheat clothes
timer cycle ends
you get clothes out now dry and put on
Apr 19, 2008 | Dryers
Dryer will not start
If if "hums" like the motors is working you drive belt may have broken. If it makes no noise other than the click it could be a blown thermal fuse (there can be several) or a seized motor.
Jun 15, 2007 | Kenmore 64722 Electric Dryer
Whirlpool WED5850SW Dryer Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
