Question about Philips 190WV
Desktop Stand ,any ideas ?
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same,as the stand I had broke. Help !!!!!!
    Problem Solver:
  • 5 Answers
You can go for a desktop stand or universal wall mount. Monitor Wall Mount will be a better option as you can use it with multiple ways you want.
Posted on Oct 07, 2015
  • 39 Answers
  • You can get a universal wall mount if the stand is no longer available or you cant find one
Posted on Jul 12, 2014
  • eddiet20
    eddiet20 Jul 12, 2014
    If the stand is no longer available, you can get a universal wall mount
2 Suggested Answers
SOURCE: I have an philips 190WV
i got the same opposite problem. my contrast goes up 100 and i can't change any thing.
have you figured out your problem? if yes, how?
Posted on Nov 14, 2010
I have a Phillips 190wv pc monitor and I am looking for a desktop stand for same as the original broke. Any ideas ?
got wood I would just build my own...cheaper and you can customize it to your like..
May 10, 2014 | Philips 190WV
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
Monitor stays in stand by mode....
Probably your SMPS watts is not enough. Compare the watts of your current SMPS with the older one. You may need to get it replaced if necessary.
Dec 27, 2009 | HP Pavilion a300n PC Desktop
Gateway pc keyboard
yes you can buy a part for keyboard stand.what you are going to do is buy a new one, or still use the old one.
Sep 02, 2008 | Gateway GT5464 Refurbished Intel Desktop...
Phillips 190wv 19inch monitor keeps on flickering leavind the display not in its full glory?
look at you video output speed.
<Control panel>::<display>settings tab::advanced button::monitor tab
once there it should shown you a slow refresh rate, set higher & the 'flicker' should dissipate, you may find that you'll want to update your video adapter as well.
Jul 18, 2008 | Computers & Internet
Is this a Software/Config/Hardware Problem ?
Apparently someone must have went into your properties, By right clicking anywhere on the desktop, Choose properties and then screen saver and then power options, Once there look into the setting for hibernation,standby,sleep make sure that they are set so not shut monitor off after so many minutes. What I am thinking is when you quit using your mouse for any amount of time it turns the monitor off. I hope that gets you going, If not you can Write back here and ask me again we can look for another solution. Thanks
Jan 17, 2008 | Dell OptiPlex GX270 PC Desktop
How do I remove the stand?
Looking at the manual
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=761&formid=3425&website=AcerPanAm.com/au&siteid=8116&words=all&keywords=&areaid=12
It doesn't appear to accept a standard VESA mount to enable mounting on anything other than the supplied stand.
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
Computers & Internet Logo
229 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
