Question about Bandai Digital Entertainment NARUTO - Naruthimetto Portable Mugenjyou no Ken for PSP
Dpfmate program will not run
Usb is connected,device screen says" usb connection", yet when i try to run it the screen says "unable to access this application." what now?
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
Try restarting u computer. or try going into ur recovery menue by presing select and prsing restart and holding the R button when it boots up again it usb mode see if u can access it like that. (dDONT MESS WITH ANYTHING IN THE RECOVERY MENUE JUST USE THE USB MODE ON IT)
Posted on Jun 30, 2009
My belkin n USB adapter (f5d8053) has been unable to access the wireless internet at my new place, through the mwn-apr150n medialink wireless n broadband router. My other devices connect fine, it's...
Please check the Network Range B/G/N Signal.
This could be the issue if other aplications are able to connect.
Also try to delete Wifi Profiles using the USB and add fresh wifi networks
If not in install & reinstall the the USB Software on ur pc / laptop
Lastly if this doesnt work try to use the USB Adapter on another network / other device and try to connect
If it doesnt then u have a USB Issue
Cheers
Eddie
Jul 02, 2017 | Belkin Computers & Internet
I am unable to use the bluetooth app in my laptop..the moment i open, it shows error 797 a connection to the remote access server was not made because the modem was not found.......please help me..........
This is for GPRS connection
You must have from your network provider: the internet access point name, your user name and password.
Download and unzip the attached file in a folder on your desktop
1- Disconnect the device from your desktop
2- On the Activesync icon on your desktop, open "Connection Settings". Uncheck "Allow USB Connection".
3- On your device: Go to "Beam" (in Settings/Connections), and uncheck "Receive all Incoming beams".
4- Then in Programs, click on "Wireless Modem". With the Connection type on USB, click on "Start".
5- Now, connect your device to the desktop. The "Found New Hardware Wizard" starts on your desktop. Click "Install from a specific location", then "Don't search. I will choose...", then click on "Modems", and "Have Disk..." and go to the folder where you unzipped the attached file.
The HTC USB Modem will be shown in the compatible hardware: click to install. Continue if you receive the alert of the software not passing the Windows XP compatibility test (Continue anyway). Finish.
6- Now, in Control Panel of your desktop, open "Phone and Modem Options". Select the "HTC USB Modem" and click on "Properties". In the "Advanced" tab type for "Extra initialization commands":
AT+CGDCONT=1,"IP","xxx","",0,0
where xxx is your internet access point.
Click OK to finish.
7- On your device (always open in the Wireless Modem program), click on Tools/Options. Check the Preset GPRS connections and write in the APN, your network provider internet access point.
8- Finally, on your desktop, go to "Network Connections" and click "Create a new connection". Choose "Connect to the internet", then "Set up my connection manually". Click "Connect using a dial-up modem", then give a name to your ISP. In phone number type *99#. Get username and password from your network provider.
Better keep a shortcut of this connection on your desktop for quick access.
Each time you want to use your device as a modem:
Disconnect your device
Disable Activesync from your desktop by unchecking the "Allow USB connection"
Open Wireless Modem on your device and push on Start (with the Connection Type on USB)
Connect your device, then dial from your desktop using the shortcut you created
PS: Remember to enable Activesync once you've finished.
Nov 16, 2010 | Computers & Internet
Lg kf350 screen ripped off how do you access txt
You can use LG suite or verizon's free program. Make sure you have the driver downloaded to your pc or it won't recognize your device. Also bitpim.org has a free program as well. Verizon's would work best.
Jan 22, 2010 | Cell Phones
I have a beetel 220bx1 modem which have 1 lan port & 1 usb port. Through lan i can access airtel broadband directly but through usb i m unable as when i plug usb cord my system ask for usb cord drivers...
if u have got the driver cd u need to run the program from it. or u can contact the airtel for the driver by calling there call center executive
Oct 30, 2009 | Computers & Internet
"Device is in use by another program" error message
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 03, 2009 | Canon PowerShot SD600 Digital Camera
DPFMate Software not available
After powerup hold down power button (just a second or two then release) to get to the menu go to usb connect press arrow and select yes. you should be able to explore your Digital Photo Frame (D.P.F.)as a usb storage device double click on DPFmate.exe It should startup manually then.
Jan 15, 2009 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
Windows will not access DPFMate format.
http://rapidshare.com/files/216551560/DPFMate_v3.8.2.9_setup.zip.html this is no longer available does anyone know where else I can get this program
Jan 05, 2009 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
Scanner Error Message
I understand that you are unable to scan from computer as well as from the printer front panel.
The issue that you are experiencing might be with the USB drivers unable to detect the printer.
However, please follow the below given instructions to resolve the issue.
Check for the communication between the computer and the printer by following the below given instructions:
To isolate the issue I suggest you to try scanning from Imaging for Windows which will scan from the all-in-one product using TWAIN software instead of the HP software.
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click Programs then Click Accessories then Click Imaging.
3.From the Imaging application, click File, and then click Select Device.
4.Select the HP all-in-one device from the TWAIN source list.
5.Click File, and then Acquire Image.
If you are unable to scan from the above steps, then confirms that the issue is with communication.
Refresh the USB composite drives to resolve the issue.
1. Right-click My Computer (in Windows XP, click Start first), and then click Properties.
2. Select the Hardware tab and then click Device Manager.
3. Click the Plus (+) sign next to Universal Serial Bus Controllers.
4. Click the USB Composite Device entry to highlight it, and then click Action and then click Uninstall. If a screen appears to confirm the deletion, confirm the deletion.
5. Disconnect the USB cable to the all-in-one, wait a couple seconds, and then reconnect the cable. This should restart Windows device detection (Plug and Play).
6. A New Hardware found screen may appear, click Next through all of the screens that appear for the Wizard to install the USB Composite Device. Click Finish once the wizard completes.
Then try scanning, even if the issue still persists uninstall and reinstall the USB drivers:
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key, this will display the Windows Startup menu.
4. Select Safe mode.
5. After Windows loads in Safe mode, right-click the My Computer icon and select Properties.
6. Select the Hardware tab and click the Device Manager button.
7. In the Device Manager Window, double-click the Universal Serial Bus controllers.
8. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
9. Click OK to confirm the removal of the device.
NOTE: Repeat steps 8 and 9 until all the devices under Universal Serial Bus Controller are removed.
The USB port is now uninstalled.
Now, restart the system. The system automatically detects and reinstalls the USB port.
Then try scanning this should resolve the issue.
If you are unable to scan from software, try running the scan diagnostic utility from the below weblink:
Here is the web link to download scan diagnostic utility:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=oj-45265-1ScanDiagnosticUtility_ver_1.5.exe
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Even if the issue still persists uninstall the complete All-in- one software and reinstall it.
This should resolve the issue.
Regards,
Lawrence
Jan 10, 2008 | HP PSC 500 All-In-One Printer
Bandai Digital Entertainment NARUTO - Naruthimetto Portable Mugenjyou no Ken  for PSP Logo
539 people viewed this question
Top Bandai Digital Entertainment Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Bandai Digital Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
