Question about Estate EED4400WQ Dryer
Replaced the eliment but didn't fix problem. Heats sometimes and doesn't at others
Out dryer started not heating so I replaced the eliment. It heats up sometimes Someone suggested changing the fuse, but can't find a fuse, or an obviouse one anyway. what should I be looking for?
aborcass
  • 2651 Answers
SOURCE: I replaced the heating element, but it still won't heat!
problably the little white thermal fuse located just to the left of the heater p/n 3392519
Posted on Mar 09, 2008
  • 2920 Answers
SOURCE: changed heating element in kenmore dryer still wont heat
limit switches
Posted on Aug 20, 2008
brentblk
  • 5 Answers
SOURCE: location of dryer cycling thermostat
The thermostat is usually on the sside of the heating element housing that runs up the back of the dryer the thermostat looks like this
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=300982
if I had the model # I could be of a little more help
Posted on Sep 15, 2009
  • 89 Answers
SOURCE: Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Posted on Sep 19, 2009
SOURCE: replaced the coil and still not heating up on my estate dryer
The thermal fuse (aka thermal limit switch) is probably blown. It is not a good idea to bypass this fuse -- if the dryer overheats, it will not cut off the heating element -- fire is likely in that scenario. If you want to troubleshoot the problem, let me know,
Charlie
Posted on Sep 26, 2009
How to fix Roper Gas Dryer RGD444OVQ1 that isn't heating?
Most likly the heating eliment went bad.Testit with the ohm meter the Replace it , if open circuit, no meter movement.
Aug 18, 2014 | Dryers
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
Dryer heating eliment not terning on
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 02, 2010 | Electrolux EIED55H Dryer
Sometimes heats, sometimes not.Ignitor is
if it just takes a long time to heat u need to check or clean your venting if not it could be ur ignitor,, or also some coils also called gas valve solenoid coil kit comes with both item number 3479 at repairclinc.com those are generic frig coils but would work fine in ur unit those fixes are allot less inexpensive then tryin to replace the timer assy
Jan 28, 2010 | Maytag MDG6000 Dryer
My dryer heats sometimes and not others. Heat goes off during
this must be a gas dryer....replace your ignitor coils let me know if you need any more help
Sep 07, 2009 | Dryers
Questions regarding an outside mirror
Heated mirrors have a swtch in the car. That operates the eliment that is stuck to the glass.This eliment heats the mirror when turned on.It is used to defrost or demist the mirror.A none heated mirror has no wires going to it and no eliment at the back off the glass.OK.
Aug 01, 2009 | 2004 Nissan Maxima
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
Estate EED4400WQ Dryer Logo
44 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
