Question about Pride Sundancer 3 Wheel Electric Scooter
How do you remove the front seat from a 1951 Mercury?
I have a 1947 Mercury with a 1951 engine, the clutch will not disengage.
probably will find that the throw out arm is not adjusted to bring the throw our bearing close to the pressure plate fingers ( assuming that every thing else is correct). The pivot ball for the arm is adjustable in the bell housing to take up so much slack. Other than that the clutch plate is not being released or the clutch plate is in back to front and the hub is hitting on the flywheel bolts.
Dec 20, 2014 | Mercury Cars & Trucks
How to remove rear seat of 1997 Mercury Sable
Most rear seats are held in with clams and screws . Look under the swab (bit you sit on) for screws or bolts holding the front of that part down. remove and lift out. Then you should see two more at the bottom of the seat back holding it in . Remove these and lift the back bit straight up off the retaining clips.. take a trip to the wreckers if you are in doubt.
Mar 28, 2013 | Mercury Sable Cars & Trucks
How to remove a drivers seat
rremove the 2 bolts in front of seat at the bottom and two at the rear bottom of seat then tilt seat and disconnect wiring and remove the seat, good luck, hope this helps.
Dec 19, 2009 | 1999 Mercury Cougar
How to remove the back seat from my 1998 Mercury Villager
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Seat, Rear Bench
Removal
  1. Remove the center seat(s) if equipped. Refer to the procedure in this section.
  1. Slide the bench seat forward to the center row seating position.
  1. Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
  1. Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
  1. Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
  1. Remove the bench seat from the vehicle through the body side door opening.
Apr 30, 2009 | 1998 Mercury Villager
Removing middle seats-procedure
in owner manual.
there are 2 release handles on each seat at front. pull up on them and then rock the seat up at the front. then slide the seat rearward to slide the "U" hooks out of the bottom slots.
Mar 29, 2009 | 2000 Mercury Villager
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
Replacing reat seat in Mercury Sable
You cn do it yourself. There are two screws on the front of the seat, as soon as those are removed then you can move the seat forward and up and out
Feb 09, 2009 | 2001 Mercury Sable
Rear seat removal 2000 merc Villager
fold top seat down first
then there is seat clip push seat forward with upward motion
this releases back floor clamps once released pull seat back this releases the front clamps then pull seat out of back door
Jul 06, 2008 | 2000 Mercury Villager
Pride Sundancer 3 Wheel Electric Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
