What is wrong when dishwasher detergent does not dissolve during wash?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 27 Answers
Try using a liquid dishwasher solution they are better for the dishwasher anyway!
Posted on May 11, 2014
The problem with my top loder panasonic washing machine is clothes dont come out clean.the liquid detergevt that i use does not always dissolve during wash and asa result clothes stiil soapyz.there are...
If you have the user's manual for this machine, check to see that you are using the recommended detergent and the correct quantity of detergent. Some machines will actually fail mechanically from using the wrong type of detergent (such as using standard detergent in a high-efdficiency washer). The pH (softness/hardness) of your water also determines how thoroughly the detergent dissolves and rinses from clothes.
Panasonic (
Q2. Why are there black stains on clothes after washing?
A2.May be your washing machine is dirty due to the residual accumulated through times and need to be overhauled. The possibility is that, a build up caused by interaction of fabric softener and detergent which can flake off from washing machine tub and stains the clothes. Try to dilute and dissolve the softener before putting it into the machine to reduce such black stains.
Spotting can also be a reaction between detergent and fabric softener, a leaking washing machine transmission, or excessive deposits of detergent or fabric softener in the tub flaking off during the wash cycle.
Good luck from Detroit, MI, USA.
Mar 01, 2011 | Washing Machines
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
Tablet will not dissolve
Either:
1. not enough water gets into the dishwasher. open the dishwasher 3-4 times during cycle, you should see some water on the bottom at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Apr 02, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher detergent clumps in pre-wash and main wash compartments
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Feb 20, 2010 | Maytag Dishwashers
I have a dishwasher when i put the detergent in it, the detergent doesn't dissolve while its washing. i often have to rewash the dishes, and it still doesn't dissolve.
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
Good luck,
Vlad
Nov 18, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Detergent cube does not disolve
Either:
Good luck,
Vlad
Nov 12, 2009 | Ariston Technologies L63 Free-Standing...
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Detergent will not dispense during the wash cycle
Something simple you can check is to make sure the spring that flips open the door is not broken or caked up with detergent.
As for the soap not dissolving, I've had similar problems and the only solution I've found is to make sure you are not blocking  the spray jet on the bottom from hitting the soap drawer.
Oct 26, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Tablet door dosn't open during cycle
It sound like a detergent cup issue (the door doesn't open at time) A very simple test for it is to place a tablet on the bottom of the dishwasher for a full cycle and to see what happen to the tablet. In case the tablet will be dissolved : - The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. - The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Good luck !
Jul 02, 2006 | Hoover 24 in. DT999 Free-Standing...
Computers & Internet Logo
David Payne
David Payne
