What is wrong when alternator gets hot in short period of time?
  • 151 Answers
Alternator could be bad or there's a short in the electrical system.
Posted on May 10, 2014
    Problem Solver:
  • 5 Answers
I don't have a lot of experience in this field, but my car had that problem once and it was the battery's fault, it had gotten bad and the alternator had to work to hard to keep up cause it did not get much from the battery. battery is the first thing I would check
I have a 1988 Honda CRV. I just put in a new alternator but forgot to take the battery cables off and blew the inline fuse. When I replaced the fuse it blows again when the battery hooks up to the...
big error that, can throw acid in the eyes, as battery explodes, if you do it wrong, so easy, lucky you did it on the safe side of fuse.?
pure random luck that, next time read the FSM before working electrics. every page tells you to pull then NEG battery lug first.
and the answer is, its shorted.
you never said the exact fuse, so i guess.
88 is very very old car,... docs hard to find.
here is the rules on electrics.
1: the fuse has a hot side, (Battery plus)
2: the fuse has a load side, (only you know this) and is shorted.
that's it, find the short by disconnecting the loads,
the fuse is expensive so I disonnect them all then add them back 1 by one till boom.
only takes 2 fuse, 1 to find it and 1 to drive after fixed.
do not fall trap to the dark side, of the force and use a jumper
for a fuse or you will have a fire, or battery acid in you face.
seen both so many times, as I yell to the guy, hey dont do that.... oops too late. NOOBS do get hurt all the time. even when warned
the battery is to be respected.
it can produces about 5000 watts of energy.
never ever, short this battery,
next post a , schematic, (close)
to post.
Sep 08, 2013 | Honda Cars & Trucks
The Microwave shut off after a few seconds. I removed it from the wall and took the cover off. I fired it up and initially it behaved the same. I checked wire connectors that were readily available. Did...
It will get hot in a very short period of time. Could you have set the time for a few seconds instead of a few minutes? Thermal issues normally take the unit out until replaced. They are one shot thermal protect devices.
Sep 06, 2013 | GE SpaceMaker Microwave Ovens
My chevy impala keeps running hot eventhough the radiator and the fluid isn't getting hot. But after running for a short period of time or trying to drive for a short period the car runs hot and c
I would start by checking the fluid to make sure it's at the proper level, Then check to see if the thermostat is opening like it should. If you have good flow and you get heat inside the car but the car still overheats I think I'd be checking for blown head gaskets and head warp.
Jan 30, 2013 | Cars & Trucks
My Fisher&Paykel Dryer gets really hot on the top and upper left back when only running for a short period of time. what is the problem?
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 13, 2011 | Fisher and Paykel Dryers
I have a 97 gmc jimmy,ive replaced the alternator twice,it starts to squeal and alternator will get very hot after 5 minutes,squeal stops if i unplug connector and ive checked it for a short with a test...
The post on the back of the alternator should`read 14 volts when running. You should get very close to the same reading at the battery posts (when the rear alternator post is hooked up to the harness).If you get any significantly different reading at either location, disconnect the harness from the back of the alternator and run a 4 gauge wire from the alternator to the positive post of the battery and see if you still have a 'hot'. noisy alternator. My guess is that the wiring in the harness is shorted somewhere.
Jan 08, 2011 | 1997 GMC Jimmy
Battery dying
Check all wiring from bat to alt.Also if aftermarket radio was installed check the wiring
Nov 02, 2009 | 2004 Hyundai Santa Fe
Please help. I have a 96 toyota camry le that keeps dying on me. At first the battery light came on and then shortly after the car died. We had the alternator tested and it was bad so we put a new one in....
You need to get someone who knows how to use a Multimeter. It is a device that registers how much voltage, is present at your battery when your alternator is charging. Anyone can use one of these tools and they are cheap to buy, just add some AA batteries. Put the negative lead on the negative battery terminal and the positive lead on the positibe battery terminal, set the device to read Voltage and read the display that tells you how much voltage is present when the car is off, then on, and when you turn on different accessories like head lights, AC, etc. your alternator should produce more Voltage with each new thing you turn on. You will see this voltage go up as you read the multimeter on the battery terminals. If you don't see the Voltage go up the alternator is bad.
Now, likely a new alternator should be good, and you said you had the batter tested, hopefully they knew what they were doing. Lastly, I would unhook the aftermarket stereo for a week or two and see if that solves the problem. Also you should check all connections to the battery and to the alternator to make sure there isn't anything loose, that was the problem on my car, the alternator conector was loose and wiggeling and caused the battery light to come on intermittently. Hope this helps you out!!!
Oct 13, 2009 | 1996 Toyota Camry
1988 Yamaha FZR 750 short circuit
HI MATE THE CABLES FROM THE ALTERNATOR LEAD INTO A FUSE BOX CHECK TO MAKE SURE THIS FUSE ISNT BLOWN IF IT ISNT GET BACK TO ME
Aug 25, 2009 | 1987 Yamaha FZR 1000
Engine starts then dies restarts but not right away
It sounds like the alternator is burned out and needs to be replaced. I hope that helps you out.
Nov 18, 2008 | 1984 Chevrolet S-10
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
